1.SEAGATE 7200.11 640GB 32MB CACHE (ST3640323AS) SOLD
Drive is perfectly healthy and is a very fast one too (check pic above)
Warranty : 4 Years 9 months Left approx. Purchased on Oct 23, 2008.
Receipt will be provided.
Specs - Seagate Technology - Barracuda 7200.11 SATA 3Gb/s 640-GB Hard Drive
Firmware Updaded to SD1B.
Drive Performing at par with 7200.12 500GB. See below
7200.11 640GB (E: ) to 7200.11 500GB (D: )
13GB Transferred in 132.55 Seconds
7200.12 500GB (F: ) to 7200.11 500GB (D: )
13GB Transferred in 132.66 Seconds
ST3500320AS (465 GB) - 7200.11 500GB 32MB
ST3640323AS (596 GB) - 7200.11 640GB 32MB
ST3500410AS (465 GB) - 7200.12 500GB 16MB
More results here - http://www.techenclave.com/storage-...ailable-nehru-place-127922-3.html#post1037162
2. MAXTOR ONETOUCH III 300GB 7200RPM 16MB BUFFER CACHE - SOLD
(USB + Firewire 400)
This drive again is perfectly healthy and achieves good speeds of ~30MB/s over USB and should achieve ~43MB/s over 1394a from what I see.
Compatible with both Macs and Windows (32bit only), The casing however is compatible with both 32bit as well as 64bit, Its only the 300GB HDD inside that doesn't work on 64bit. The casing also works with 1TB drives and possibly larger HDD's.
A very sturdy build of excellent quality. Comes with the original power adapter and original high quality USB 2.0 Cable (5 Feet 9 Inch), even the power cable is fairly long.
Feature include Onetouch backup, DriveLock password protection, data sync between two or more computers, and system rollback
Warranty - Out Of Warranty. Though the drive is perfectly healthy.
No Issues what so ever.
Complete Specs - Maxtor OneTouch III External USB 2.0/FireWire 400 Hard Drive (300GB) specs and Hard Drive specifications - CNET Reviews
Review - Maxtor OneTouch III External USB 2.0/FireWire 400 Hard Drive (300GB) Hard Drive reviews - CNET Reviews
DELHI/NCR Buyers Preferred.
No Lowballing Please. Use PM.
I just thought I'd share how well I packed the hdd I sent to ajinkya, for future references..
