sudan_rulz
On sale is 120 mm Sunbeam silent LED Purple UV light fan.
Got it around 2 months back..
Used for a week..Since then lying IDle..
Link: ImageShack -..
Specs:
Specifications:
Size: 120 x 120 x 25mm
Rated Voltage: 12VDC
Bearing Type: Sleeve
Rated Speed: 1200rpm +/-10%
Air Flow: 45.21cfm
Air Pressure: 1.21mmH2O
Noise Level: 21.75dB(A)
Input Current: 0.16A +/-10%
Power Consumption: 1.92W +/-10%
Speed Sensor: Yes
Cable Length: 600mm
Life Expectancy: 30,000 hours
Plse PM for further details / clarifications..
Specs:
Specifications:
Air Flow: 45.21cfm
Speed Sensor: Yes
Cable Length: 600mm
