Delta Fans 120mm, 120CFM HIGH SPEED LOW NOISE @ Rs 500 shipped.
mediahome.in
Feedback: 185 / 2 / 0
Delta AFB1212HHE 120x38mm High Speed Fan
<-- Comes with an additional removable grill.
Product Details:
[FONT=tahoma,arial,helvetica,sans-serif]The Delta AFB1212HHE is their highest output 120x38mm AFB series part, with an impressive 120+ CFM. It can be controlled by most respectable fan controllers thanks to its reasonable 5.52 watt power requirement. It utilizes the traditional AFB blade design, features a tach output and like every Delta we stock, uses ball bearings for long life. In addition, it is available in a 3 pin configuration
[/FONT]
[FONT=tahoma,arial,helvetica,sans-serif]Specifications: [/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]120x120x38 mm[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]120 CFM @ 2900 RPM[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]44.0 dBA[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]5.52 watts[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]0.46 amps[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]Maximum Air Pressure 9.0 mm H²O[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]12v DC[/FONT]
  • [FONT=tahoma,arial,helvetica,sans-serif]3 pin connector(s)[/FONT]
Price
: Rs 500 shipped.
Delta AFB0912HH 92x25mm
pcpartscollection_2048_4260780
Specifications :
[FONT=arial, helvetica]Connector: 17-Inch, 4-Pin & 4-Wire
Dimensions: 92 X 92 X 25 mm (3.6 X 3.6 X 1 in)
Power: 12 VDC (7.0 to 13.8) 0.4 Amp
Speed: 3200 RPM
Max Air Flow: 57.92 CFM
Noise Level: 38 dBA
[/FONT]​
Price : Rs 400 shipped.
zanderzone
Feedback: 72 / 0 / 0
@ mediahome.in ---> can the Delta AFB1212HHE be connected to regular motherboard or 4 pin molex connection or does it require any special arrangement ?
SidhuScorpion
Feedback: 35 / 0 / 0
^ Normally upto 1200RPM fan is silent, upto 1900RPM its tolerable, above its loudy.
U wont find High CFM + Silence in same fan, its performance fan.
mediahome.in
there is one common funda : More RPM MORE PERFORMANCE MORE SOUND, but i have it on my own PC , with the room fan on i cant hear a thing
