Search
Search titles only
By:
Search titles only
By:
Forums
New posts
Search forums
What's new
New posts
Latest activity
Feedback
View Statistics
Members
Current visitors
Buy Sell Trade
WTB
Log in
Register
Search
Search titles only
By:
Search titles only
By:
New posts
Search forums
Menu
Install the app
Install
Reply to thread
Forums
Technology
Computer Software
VIRUS Problem - Help required
You should upgrade or use an
alternative browser
Message
<blockquote data-quote="krishnavamshi24" data-source="post: 750183" data-attributes="member: 12723"><p>Mate get Avast home edition free software do a boot scan so that it can remove the file...simple steps to do that are given below </p><p></p><p>Download and install Avast </p><p></p><p>Restart PC</p><p></p><p>Right click on the Avast system tray icon</p><p></p><p>Click on “Start Avast Anti Virusâ€</p><p></p><p>Avast anti virus window will pop up and run a memory scan</p><p></p><p>Once memory scan finish, you can right click on the Avast anti virus window and select “Schedule Boot Time Scanâ€</p><p></p><p>“Schedule Boot Time Scan†window will popup, select “Scan all local disk†and check on “Advanced Optionsâ€</p><p></p><p>For normal infected file select “Move infected files to Chest†and select “No action†for system files and Press “Schedule†button.</p><p></p><p>Avast will prompt you for restart to perform the Boot time scan and click “Yes†to reboot and start the scan.</p><p></p><p>Done you have just scheduled a boot time scan from Avast anti virus</p></blockquote><p></p>
[QUOTE="krishnavamshi24, post: 750183, member: 12723"] Mate get Avast home edition free software do a boot scan so that it can remove the file...simple steps to do that are given below Download and install Avast Restart PC Right click on the Avast system tray icon Click on “Start Avast Anti Virus†Avast anti virus window will pop up and run a memory scan Once memory scan finish, you can right click on the Avast anti virus window and select “Schedule Boot Time Scan†“Schedule Boot Time Scan†window will popup, select “Scan all local disk†and check on “Advanced Options†For normal infected file select “Move infected files to Chest†and select “No action†for system files and Press “Schedule†button. Avast will prompt you for restart to perform the Boot time scan and click “Yes†to reboot and start the scan. Done you have just scheduled a boot time scan from Avast anti virus [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
Technology
Computer Software
Bottom
