gaganjain
µTorrent is an efficient and feature rich BitTorrent client for Windows sporting a very small footprint. µTorrent was designed to use as little cpu, space and memory as possible while offering all the functionalites expected from advanced clients. With BitTorrent, you can download files faster and contribute by sharing files and bandwidth.
Features of "µTorrent":
· Multiple simultaneous downloads
· Smart bandwidth usage
· File level priorities
· Configurable bandwidth scheduling
· Global and per-torrent speed limiting
· Quickly resumes interrupted transfers
· UPnP support (WinXP only)
· Supports popular protocol extensions
· Trackerless support (Mainline DHT)
· Localized to different languages
· Typical memory use less than 6 MB
· Incredibly small: about 200 KB
The biggest changes were full Vista support and the removal of the 65,536 piece limit for torrents.
Also added was support for finding local peers (peers on the same LAN) and optionally not having any upload restrictions for them.
It is also possible to turn on automatic updating for betas now, found in the "Other" section of the preferences.
Changes in µTorrent Version Version 1.7.5
- Fix: rare crash bug with malformed UPnP response
- Fix: downloads stalled in rare cases
Download : µTorrent 1.7.5 Build 4602
