sabret00the
Hi guys I need a Converter which can convert the voltage of a electrical gadget bought from USA rated 110-120v 60Hz to 220-240v 50-60Hz rating so that I may use it in India.
Can someone help me in this regard?
I have searched on ebay and found the two adapters as mentioned below:
eBay India: Voltage Convertor 220 Volt to 110 V 1600 watt (item 140440354378 end time 21-Aug-2010 14:11:33 IST)
eBay India: voltage converter 220volts to 110 volt 250watt 250w (item 140428708064 end time 23-Aug-2010 00:00:00 IST)
I'm not sure if these would solve my purpose or not? :huh:
