4G/LTE USB modem
Do keep us posted if you manage to get it working with pfsense. Even ill pick it up then :)
You can get it working, the issue is when the device reboots, the interface will be missing.
I work around this issue by using a DIR505 with ROOTer (essentially double NAT) with a standard JioFi/Phone, but can get ipv6 to work.
That DIR-505 is an interesting device. Looks it supports openwrt as well.
Does the stock firmware support 3g USB device?
I dont think so. You will need to flash with ROOTer. The reason for choosing the DIR 505 over the TPLink 3020 is that the larger memory for the 505 allows for IPv6 integration(ROOTer).
I have no experience with ROOTer. What is their website?
My device of choice is GL-MT300n. It comes with out of the box support of openwrt, has dual WAN connections and a USB port.
That ROOTer firmware seems to be a spinoff of openwrt. Does it add anything more than what openwrt provides?
I dont know whether GL-MT300n is available in India, but it sure is on Aliexpress.
Anybody has a recommendation for a 4G/LTE modem which works on Indian 3g/4g frequencies?
E-398 from Huawei and MF833T from ZTE are superb! you may try other models marketed by various ISP in India but, basically All the 2/3/4G, LTE modems are manufactured by these two major Chinese Brands only!
I got the Airtel branded E3372h-607 modem from ebay. Out of the box it was a hilink device and came with Software version 22.200.15.00.00 and WebUI version 17.100.06.00.03. Here are some basic steps to convert it to a stick mode (modeswitch not required).
1. Follow needle method using T5 screwdriver and erase the firmware using https://github.com/forth32/balong-usbdload
Code:
# ./balong-usbdload -p /dev/ttyUSB0 usblsafe-3372h.bin
 Аварийный USB-загрузчик Balong-чипсета, версия 2.03, (c) forth32, 2015
 * Удалена процедура flash_eraseal по смещению 000052c4
 Компонент    Адрес    Размер   %загрузки
 raminit    00000000     3412   100%
 usbboot    57700000  5922289   100%
 Загрузка окончена
2. Flash the firmware using https://github.com/forth32/balong-usbdload and firmware "E3372h-607 21.110.99.02.00 general" from https://www.lteforum.at/mobilfunk/firmware-versionen-hi-non-hilink-e3372h-inkl-mod.2691/
Code:
# ./balong_flash -p /dev/ttyUSB2 E3372h-607_UPDATE_21.110.99.02.00.BIN
 Программа для прошивки устройств на Balong-чипсете, V3.0.280, (c) forth32, 2015, GNU GPLv3
 Код файла прошивки: 9 (ONLY_FW)
 Цифровая подпись: 2958 байт
 Хеш открытого ключа: SOME_SORT_OF_HASH
 Версия прошивки: 21.110.99.02.00
 Платформа:       BV7R11HS
 Дата сборки:     2014.11.19 06:22:57
 Заголовок: версия 1, код соответствия: HWEW11.1
 Режим цифровой подписи: ONLY_FW (2958 байт)
 Версия протокола: 7200B--SKCBADZM
 Идентификатор устройства: HUAWEI BV7R11HS
##  ---- Имя раздела ---- записано
00  Fastboot              100%
01  M3Boot_R11            100%
02  M3Boot-ptable         100%
03  Kernel_R11            100%
04  VxWorks_R11           100%
05  M3Image_R11           100%
06  DSP_R11               100%
07  Nvdload_R11           100%
08  System                100%
09  APP                   100%
 Перезагрузка модема...
The device now appears as a USB serial device,
Code:
usb 3-6.4: GSM modem (1-port) converter now attached to ttyUSB0
option 3-6.4:1.1: GSM modem (1-port) converter detected
3-6.4: GSM modem (1-port) converter now attached to ttyUSB1
option 3-6.4:1.2: GSM modem (1-port) converter detected
usb 3-6.4: GSM modem (1-port) converter now attached to ttyUSB2
Code:
 Загрузка окончена
Code:
 Платформа:       BV7R11HS
00  Fastboot              100%
01  M3Boot_R11            100%
03  Kernel_R11            100%
04  VxWorks_R11           100%
05  M3Image_R11           100%
06  DSP_R11               100%
07  Nvdload_R11           100%
08  System                100%
09  APP                   100%
Code:
That seems promising, did you get it working with pfSense and Jio?
The modem is detected as a serial device in pfSense without any fuss.
Code:
#dmesg
ugen0.2: <HUAWEIMOBILE HUAWEIMOBILE> at usbus0
u3g0 on uhub0
u3g0: <HUAWEIMOBILE HUAWEIMOBILE, class 0/0, rev 2.10/1.02, addr 11> on usbus0
u3g0: Found 3 ports.
#usbconfig -d ugen0.2 dump_device_desc
ugen0.2: <HUAWEIMOBILE HUAWEIMOBILE> at usbus0, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=ON (2mA)
  bLength = 0x0012
  bDescriptorType = 0x0001
  bcdUSB = 0x0210
  bDeviceClass = 0x0000  <Probed by interface class>
  bDeviceSubClass = 0x0000
  bDeviceProtocol = 0x0000
  bMaxPacketSize0 = 0x0040
  idVendor = 0x12d1
  idProduct = 0x1c05
  bcdDevice = 0x0102
  iManufacturer = 0x0001  <HUAWEI_MOBILE>
  iProduct = 0x0002  <HUAWEI_MOBILE>
  iSerialNumber = 0x0000  <no string>
  bNumConfigurations = 0x0001
The serial devices are cuaU0.0, cuaU0.1 and cuaU0.2.
