WTB A.M.D. Ryzen Wraith Prism LED RGB Cooler Fan
swagatrath
Nov 29, 2014
509
188
82
Bangalore
Feedback: 8 / 0 / 0
The processor is Ryzen 5 3600 and am using H45 cooler
The performance is good
All parts I bought from primeabgb, vedantcomputers and amazon.in
Though the cooler is bought from amazon
I just received the cooler from itdepot yesterday.. Found liquid vapor bubbles in the packaging itself..
Pics - https://ibb.co/6XmJx9c
https://ibb.co/Np7MTC1
Is that normal?
It did not fit in my case and had to install it using jugaad method to make it work..
When I switch on the PC I hear bubbles sound like one would if you blow into a straw while drinking any liquid.. Again is that normal?
It goes away about 20~30 secs after its switched on but I can hear it again when CPU is under load..
SunnyBoi
Veteran
Jan 31, 2005
4,470
468
172
34
Bangalore
www.funenclave.com
Feedback: 34 / 0 / 0
Is that normal?
No, it is not normal. The cooler has clearly been damaged and is leaking. Id suggest you take it off soon or maybe put lots of tissue papers around the pump and radiator to detect any leak
That is because of cavitation caused by the pump. Its kinda normal when the pump starts at first but it shouldn't happen again.
Reactions: Crazy_Eddy
bssunilreddy
Veteran
Mar 24, 2007
2,146
846
208
41
Nellore
plus.google.com
Feedback: 17 / 0 / 0
Is that normal?
The radiator is leaking coolant. Just RMA it immediately.
My cooler is working great.
Raise a ticket with Corsair and they will ask for invoice.
Send it and if you have a service center nearby then it's okay. Otherwise you need to hand them over personally.
