PC Peripherals Advice for building a PC config ?
shantanugoel
Active Member
Dec 31, 2008
304
8
32
tech.shantanugoel.com
I need a cheap and low power PC that I can use to make builds overnight (My lappy gets very hot while doing long duration compile sessions and also becomes unusable for that much time, so not intending to use it). Can anyone suggest a cheap config for the same? But it should be powerful enough to carry out huge compilations (like a full linux distro) in a reasonable time and run cool and be light on power consumption (so as to use with ups to avoid session breaks during power outages). Also smallest form factor possible :)
Budget as less as possible, max 8-10k.
Is the above combination even possible in that budget range?
Would an atom PC be good for that?
Just saw a few other threads so thought of adding info in a proper format:
1. Q: What is your budget?
1. 8-10k
None
None
This will be a headless system, so basically CPU + MB + Cabby + HDD + RAM
Might add an optical drive later
Online or Hyderabad
Yes (except HDD)
Build PC and download rig (and occasional movie playback to TV)
A.NONE
No gaming
1. No
Any flavour of linux (prefereably Debian or debian derived like Ubuntu)
sunny27
Stig's Indian Cousin!!!
Veteran
Oct 7, 2009
2,190
218
103
32
Top Gear Test Track
get these
iball nettop 009 cabinet with psu-1200
intel atom dual core 330 with the board around 4600
2gb of ddr2 ram -transcend-around 2000rs
would set you back by 7600-7800rs.
i believe you have the other components.
this would be a good low power consuming web surfing rig! doubles up as a download server!
DarkAngel
Veteran
Apr 10, 2009
6,419
320
222
ATOM D945GCLF-ATOM board + ATOM 1.6 GHz - 3.1k
2GB DDRII 800MHz Transcend - 2k
Seagate 500GB 7200.12 - 2.4
IBall nettop 009 cabinet with PSU - 1.2k
So total 8.7k :) The single core atom will do for a browsing rig with Linux. if you need more power then consider the dual core atom for 4.5k. But for that much money you can get a AMD Sempron 140(1.85k) + Asus M2N68-AMPLUS(2.45k) - 4.3k. This is better than the dual core atom setup
shantanugoel
Active Member
Dec 31, 2008
304
8
32
Thanks guys. These configs are good starting points for me to do more analysis. Actually since this is a build pc it would require more horsepower as compared to a normal browsing\general purpose PC I guess.
Another thing is do you think these will be low power enough to be sustained on a UPS for about an hour as I wouldn't want my builds to be disrupted by outages (Just bashing my head now why I didn't buy a UPS with a usb link, with which I could have monitored the remaining backup time and did graceful shutdowns and all)
otpsurvive
New Member
221
3
0
33
Well, Though the Atom is a low power consuming processor, it is a serious bottleneck. The whole platform is meant for just light computing and generally for online apps. For your compilation and other stuff that require power, you need to look at a dual core or something. I would suggest the Athlon II X2 240 with a 785G chipset MoBo with minimum 2GB RAM. (DDR2 is cheaper, I’d suggest getting that and the compatible MoBo). Any cabinet and a seagate 7200.12 500GB HDD. That would leave you poorer by approx 12k but will be well worth the extra.
