Raghunandan said:The Dell 2209 is also full HD and quite good if you dont use 16:9 resolutions. The Benq T2200 is good too.
krazypop said:Dell 2208 WFP even though its displayed on Dells India's website.. is not available with them. Spoke with Dell customer support people and the availability was negative. It seems they have stopped production or so. Basically I am looking at LCD with S-IPS panel which would be good for my main purpose Designing.
morgoth said:There is no such thing as S-IPS panel 22" within 15K. I suggest you go for a 19" monitor based on S-IPS or M-PVA. You may get something from HP, Dell or Samsung for under 20K.
22" S-IPS or M-PVA will cost you at least 30K upwards
VOiLA said:getting the Benq E2200 HD within a week.
I have 2 questions.
1. is it better than Dell S2209W ?
2.I want to mount it on the wall ! is it possible ? any wall mounts available @ cheap $ ?
//thanks
Crazy_Eddy said:HP have a 22" S-PVA screen too, the LP2275w. Not sure on the pricing, but thats supposed to be around the 20k mark as well.
Crazy_Eddy said:Yeah the WFP has been phased out here. Only the FP is available now.
BTW why did they quote a price point if its not available? Or did they mean they can arrange for it?
