Airtel GPON HG8145V Supported USB file system formats
skoka123
May 2, 2008
469
133
132
Does anybody know about file systems the GPON device supports in USB mode. Can someone please help me get the user manual?
vivek.krishnan
Veteran
Dec 18, 2009
7,469
1,675
303
Ghatkopar, Mumbai
plus.google.com
A bit of googling reveals a similar named product called EchoLife HG8145V GPON Terminal
This link [http://www.3bb.co.th/uploads/20180124101654EchoLife HG8145V GPON Terminal_Eng.pdf] says that it supports USB storage devices.
This link gives more info, but unknown if relevant - https://forum.huawei.com/enterprise/en/Q-A-How-to-use-the-USB-function-of-a-Huawei-ONT-HG8045A-HG8245-HG8247H/thread/464849-100181
I would wager it would support FAT/FAT32. On the Linux side, EXT2/3 and XFS etc should be supported as well. NTFS, well, if they have added the module then yes, but don't hope for it now.
skoka123
May 2, 2008
469
133
132
Thanks Vivek. I have already looked up both of the above. They do not tell what exact file system formats the device supports. I have a WD My Book 6 TB which seems to exFAT. Basically I just want to store all my media in the external drive connected to the router and access it from various devices at home (Shield TV, Fire TV Stick, Laptops etc).
