dilpreet
Guys i am currently using the following configuration:-
MSI 785G-E53
7950 powercooler
CM 650M PSU
3 X 2GB CORSAIR 1333,1 X CORSAIR 1600(Both are standard memory modules)
Phenom x4 965BE
But looks like the Mobo has an issue now where the Bios settings are not getting saved.
So i need suggestions from fellow members with respect to the following :-
1.Since i have tried most of the steps to fix the bios reset problem and i don't see that getting fixed so
can i get it fixed from local computer shop(Warranty is expired) and is it worth getting it repaired?
2.In case it cannot be fixed which motherboard should i buy in range 5-6k MAX(Proccy used is Phenom 965BE)
3.Which brand should i go for now?
Kindly suggest urgently .
MSI 785G-E53
7950 powercooler
CM 650M PSU
Phenom x4 965BE
