Android for 20 K
kpkini
Q: Budget?
A: 20k
2. Q: Preferred Form Factor(flip, bar, slider)?
A: Bar
3. Q: Preferred display type?
A: TFT
4. Q: Do you have any brand preference or dislike? Please name them.
A: Want to buy only Nokia's phone.
5. Q: Preferred input method (Touchscreen, QWERTY, etc.)?
A: Touchscreen
6. Q: Camera required or not? If required, please specify type like front camera/flash/etc.
A: Required a 5MP camera. Flash.
7. Q: Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
A: Android
8. Q: Preferred connectivity options? (3G, Wifi, Edge etc).
A: 3G. and wifi
9. Q: What is your intended use for this phone(internet, camera, multimedia, mails, etc)?
A: Music, internet, camera, games in that order
10. Q: Any other requirements?
A: large screen atleast 4 inch
11. Q: If you have already considered a phone then please mention the model.
A: Xperia Neo L - Sony Xperia Neo L: Price in India, Reviews, Specification: Flipkart.com
Xperia Go - Sony Xperia Go: Price in India, Reviews, Specification: Flipkart.com
Lg L7 - LG Optimus L7 P705: Price in India, Reviews, Specification: Flipkart.com
Don't buy a single core device for 20k cause it isn't worth it & you'll also have a handset which lags while browsing.
I would suggest you to increase your budget by 1-2k and get a Galaxy S Advance locally where it would be available for around 21k-22k. It has much better specs than the handsets you have listed above.
Here are it's specifications: http://www.gsmarena.com/samsung_i9070_galaxy_s_advance-4469.php
Others you can consider:
- Xperia sola (which also is a pretty good handset but has 3.7" screen)
Specs: http://www.gsmarena.com/sony_xperia_sola-4408.php
- Motorola Atrix 2 (@arnd 21k but most don't prefer motorola)
Spec: http://www.gsmarena.com/motorola_atrix_2-4199.php
Do update here on what you finally buy.
Hope this helps. :)
this is not true. Only HTC One V has browser problem but i doubt if any single core based mobile will get Jelly Beans update officially. Also at 20k, single core mobiles makes no sense.
Spec: Motorola ATRIX 2 - Full phone specifications
+1 to this. Atrix 2 is a fantastic handset but most are paranoid to take Motorola's route as it doesn't have Nokia-type service center in all cities. And it'll get ICS update too.
OOps sorry ...missed the brand preference question .... left it as in the template ...
Brand that i would prefer is sony ... because good music player is a must followed by camera and a 4 inch screen .........
6 k more for a dual core ?? i dont need the bang for gaming .. not a priority .. Besides no SD card slot in P ... Xperia P still hasn got the promised ICS update what hopes for the Jelly bean !!! My only gripe with Neo L is Internal memory of not even half GB !!! Is it gonna matter if i put a SD card ??
What ridiculous comparison is that ? Don't go by that.
Atrix 2 camera n music is average.
Better go for Sola than Neo L
Xperia P ICS update will arrive next month. 4 weeks left. U will also get in that same period. Sola will get ICS in early September.
Sola has a smaller screen ,... need atleast 4 inch screen for browsing and for reading PDF / e books...
---------- Post added at 06:20 PM ---------- Previous post was at 06:14 PM ----------
Xperia P with a SD card slot would have been perfect ... could have upped the budget by 6 k and bought it ....
