Android Android Remote for Android PC
Greetings everyone,
I have a PC with Android as it's OS running natively. I have a spare android phone that I want to use it as a remote for the android pc through wifi or Bluetooth since there is no IR sensor in the android PC
Is there any app that can serve my purpose?
http://www.openthos.org/
It is in Chinese, so you may need to use google translate. During installation, you have the option to select English though
I gave it a try, found it better than other alternatives, unfortunately, my graphics card driver is not supported, so choppy video.
ohh, its that variant.. i had checked it. Its quite at early stage i suppose. Didnt know its called thos :D
