android tv boxes
kippu
Veteran
Dec 28, 2006
2,020
237
152
Any experience with them? or with the advent of smart tv , these boxes are not required?
meetdilip
Oct 9, 2011
668
106
81
There are a few threads on this forum. Many people here use it too. If you ask me, it still have market in India.
chetansha
Veteran
Jun 30, 2007
1,882
822
202
Coimbatore
Yes. I am using h96 pro on vu non smart tv. Over all good experience. Boxes can be updated and customised, kodi can be installed on it.
Not sure if you can do the same on smart t.v.
cute.bandar
Oct 7, 2010
297
81
67
32
smart tv can be expensive as compared to non-smart versions at certain screen sizes. tv boxes definitely have a thing here.
I have a 40" normal tv, with a mi box and I LOVE it.
make sure to not get a shitty smart box
nikhilpoddar
149
5
82
36
@chetansha. Can u help me with h96 pro. Where did u get it from in India? Does it come with Bluetooth Remote?
kippu
Veteran
Dec 28, 2006
2,020
237
152
now confused wth the myriad of options :D ... m96x vs m8s mini
chetansha
Veteran
Jun 30, 2007
1,882
822
202
Coimbatore
I got it from bangood. Got hit customs duty of 41% on customs assesed value of 5k.
It comes with a remote, not sure if it bt or ir. I probably think it's ir
https://www.banggood.com/H96-PRO-PL...p-1100082.html?rmmds=myorder&cur_warehouse=CN[DOUBLEPOST=1521003353][/DOUBLEPOST]
VU tv coming out with Android 7 TV's . check out flipkart, willbe available from 16th onwards
sbhas2k
Feb 28, 2010
623
146
132
Mumbai
Mi box is the best bet. Have acquired one recently and very happy with it. Netflix can stream at 4k/1080p whereas other android boxes will be limited to 480p i guess!!
Plus very stable
mav2000
Veteran
Dec 19, 2008
2,155
287
172
41
Kodi seems to have stopped working for the last month or so for me.
cute.bandar
Oct 7, 2010
297
81
67
32
^Try SPMC.
Getting Chromecast is pointless if compared to mi box. Since mi box has chromecast builtin, has voice remote, kodi, x265 , and costs the same if no customs.
meetdilip
Oct 9, 2011
668
106
81
I am not sure how good Mi Box international version is in India. What's the total cost once you were able to buy ?
Firestick has an app store, supports sideloading of Kodi and so on.
cute.bandar
Oct 7, 2010
297
81
67
32
I got the mi box for only 66$ (and not 33$ as I earlier thought), no customs, but another guy wasn't as lucky.
mi box also has a play store (with some apps), others can be side loaded. kodi / spmc are available in the play store itself.
Reactions: meetdilip
cute.bandar
Oct 7, 2010
297
81
67
32
OOPS! I actually got it for 66$ , got the price confused with the mi mini router or something else :oops:
dissel
Sep 23, 2007
887
236
132
Kolkata,WB
There is a new Mi Box launched to replace the current one - So I suggest wait for the new one. The New one equipped with Patchwall AI of Xiaomi.
Reactions: tommy_vercetti
sbhas2k
Feb 28, 2010
623
146
132
Mumbai
Mi box 3, which I currently use is good. Mi box 4, which was recently launched have the same processor & configuration as old one, except a patchwall which is a custom skin on top of Android TV OS
One can buy either one of these without any issues. Currently, i have the following Apps installed & working on MI box 3 (international version)
- Kodi
- Amazon prime (Nvidia shield Version, other versions will force close)
- Jio TV
- Firefox etc
- Netflix with 4k streaming
- Airplay app for streaming from Apple devices. Works pretty good
The apps which fail to work
- Amazon Music, Jio Music, and Wynk
I am using it with RII Remote as well as with MI remote. I have connected a USB hub, connected 16GB USB pen drive and using it as an internal storage.
Hope I have provided enough information :)
vyral_143
Jarvis
Super Mod
Nov 28, 2011
3,325
1,451
207
香港
I am using X96 box which I got for $30. It has S905X and 2GB RAM + 16GB storage. It works good and main apps I use with it are Amazon Prime, Sony LIV, HotStar and Popcorn Time. IMO, one should save by buying non-smart TV and spend on such boxes.
Reactions: Arv90 and sbhas2k
sbhas2k
Feb 28, 2010
623
146
132
Mumbai
Yep. Have the same opinion :)
