Budget 0-20k Antec dark avenger cabinet alternative suggestions required
princeoo7
On a Journey called Life :P
Jun 10, 2010
1,246
52
86
Mumbai
Guys any better or same alternative to antec dark avenger case within 7k ?
- The only issue I have is this cabinet don’t have rubber cover to hide the cables.
- ships with 2 fans only and a video suggest the front fan is noisy.
- Some one on a video complained about side glass getting hot, don’t know if that’s a big problem or not but that’s that.
The only thing this cabinet got me attracted is the support of 360mm radiator on both, top and front side and support for a 400mm gpu card.
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Corsair SPEC DELTA RGB @ 5k
princeoo7
Jun 10, 2010
1,246
52
86
Mumbai
Don't go with ANT as we don't know their RMA process.
If you go with Corsair then you can use 360 RAD at front.
Yes i do have a good experience of corsair
I am just concerned about the big GPU and 360mm radiator being not fitted up-close.
