Anybody using LED Grow Lights?
skoka123
May 2, 2008
470
135
132
Hi,
Anybody using LED Grow Lights here or know of any forums that deals with Hydroponics and Indoor plant growing?
Thanks,
Srikanth
Dr.Lakshay
Member
30
18
16
What a coincidence. I just ordered two grow lights on Aliexpress! Will take some time to see the results
skoka123
May 2, 2008
470
135
132
WoW!! Link Please. I saw some grow lights (50W) on amazon for ~1.7K. Not really sure how it will work though the reviews are positive I do not think anybody really used them for even one crop cycle.
Dr.Lakshay
Member
30
18
16
These are the ones that I ordered :
US $1.26 31%OFF | 80leds 220V LED Grow Lamp Full Spectrum LED Plant Growth Lamp Indoor Lighting Grow Lights Plants Vegs Hydroponic System Grow Box
US $4.05 | E27 Full Spectrum 20W 30W 40W 80W 100W 150W LED Plant Grow Light Bulb Fitolampy Phyto Lamp For Indoor Garden Plants Flower
Will use them in my kitchen garden as I don't get any direct sunlight there. I used one cheap USB powered one which came free with screen guard and it does show little increase in growth in my tomato seedlings. So I hope these bigger ones will definitely help.
Use my invite code to join Aliexpress if not already joined:
Use my invite code "ING24IC1" to get US $19 in coupons. Tap to know more: https://s.click.aliexpress.com/e/KCHP47R6
blr_p
Veteran
Apr 11, 2007
6,212
1,367
301
Since you guys are into hydroponics what is your experience with pH meters ?
I'm surprised how much care & babying is required if you want them to remain accurate and have delayed my purchase for now.
skoka123
May 2, 2008
470
135
132
I am not sure what you mean by experience with pH meters. As a hobbyist the pH / EC / TDS meters are all pen type. They do need calibrating every once in a while especially the pH and EC meters. I typically only buy Hanna make.
Coming to grow lights, it does not have to be used only for hydroponics right? I intend to grow various herbs in couple of dark rooms in my house. Growing cilantro in summers is a big challenge even with shade nets etc. So, I plan on growing Cilantro, Spinach etc during summer indoors. Now, I may or may not go for Hydroponics with them. It could well be a regular pot/grow bag filled with cocopeat and regular feeding of nutrient solutions.
Within Hydroponics itself there are many simple ways of growing short term plants / herbs without worrying about pH, EC etc. The simplest method is to go for Kratky. Though your yield might be around 20 to 30 less than say DWC or NFT the simplicity of Kratky is worth the sacrifice.
blr_p
Veteran
Apr 11, 2007
6,212
1,367
301
The bulb of a pH meter needs to be kept moist otherwise it can get damaged or accuracy can be affected. That means a monthly checkup if the pH meter is used sparingly.
You don't have to do this with EC/TDS meters.
skoka123
May 2, 2008
470
135
132
Do you do hydroponics?
skoka123
May 2, 2008
470
135
132
@Dr.Lakshay - Any feedback on your grow light performance?
I have finally received my grow light yesterday. Will put it to use in about a week.
TechFrost
Member
38
1
8
Even am planning to buy a pH meter, is the accuracy of the Hanna good enough to match with test solutions ? How often do u change the electrodes ?
skoka123
May 2, 2008
470
135
132
Hanna Pen type pH meters do not have a replaceable electrodes. They are fairly reliable for my Hydroponic usage considering that they cost around 400 - 500 only. You get a pH solution (I think the one I have is pH 7). I adjust the pH of the meter to 7 to calibrate once in a while when I think things are off. Typically I do not after every 20 to 30 readings. The calibration itself is very easy. You just need to turn the screw until it measures the known pH (7 in my case).
TechFrost
Member
38
1
8
Sounds good. Where did u purchase for 500 ?
Dr.Lakshay
Member
30
18
16
It's been working good. I'm planning to buy a couple more to grow fruit trees without direct sunlight.
These 8-10w bulb can cover 2-3 pots ideally.
rdst_1
Veteran
May 10, 2009
2,558
1,148
253
32
You can get it at Amazon.in.
Hi,
I had bought a HM Digital PH meter from Amazon a few months ago. I haven't opened it since then as my experimental hydroponic setup is still not in place. Would the liquid that was in the sponge inserted in the cap kept the electrode safe till now?
Or is my pH meter pretty much gone and I would need to order a new one
skoka123
May 2, 2008
470
135
132
Hi,
You should be fine.
Reactions: rdst_1
