Just got the message too. Guess I can finally ditch BSNL.
Can anyone with beam cable ping the above ip address and let me know what pings you are getting?
Pinging 220.226.181.83 with 32 bytes of data:
Reply from 220.226.181.83: bytes=32 time=15ms TTL=114
Reply from 220.226.181.83: bytes=32 time=16ms TTL=114
Reply from 220.226.181.83: bytes=32 time=17ms TTL=114
Pinging 111.119.212.202 with 32 bytes of data:
Reply from 111.119.212.202: bytes=32 time=16ms TTL=57
Reply from 111.119.212.202: bytes=32 time=17ms TTL=57
Pinging 120.138.101.243 with 32 bytes of data:
Reply from 120.138.101.243: bytes=32 time=35ms TTL=121
Reply from 120.138.101.243: bytes=32 time=59ms TTL=121
Reply from 120.138.101.243: bytes=32 time=50ms TTL=121
Reply from 120.138.101.243: bytes=32 time=45ms TTL=121
Reply from 120.138.101.243: bytes=32 time=46ms TTL=121
Reply from 120.138.101.243: bytes=32 time=20ms TTL=121
Pinging 202.156.3.176 with 32 bytes of data:
Reply from 202.156.3.176: bytes=32 time=60ms TTL=110
Reply from 202.156.3.176: bytes=32 time=59ms TTL=110
PS : Forgot to mention, the given log is off a Hyd beam connection.
