This is super attractive, probably a typo or something. But still I would place the order with COD option. And buy a compatible H170 motherboard, both will fit your budget comfortably.
May be it's not typo.
If you're not interested in Xeon, you can go for i5. i7 + mb will cost about 33k, a little over your budget.
