Audio Best earphones with mic under 2k
hirumon
Hi,
I am looking for a good budget earphones with mice to use with my android phone.
My budget is 2k. Bought a SM E10C from amazon but found the bass is practically non existing.
Returned it sayingmanufacturing defect.
What are the options available other than SM?
Any help is appreciated..
Thanks[DOUBLEPOST=1487439625][/DOUBLEPOST]bump...
I ordered a KZ ATR and I am waiting for the package to get delivered. It has good reviews and at $5, I wouldn't mind if they break in a few months and may even go for a couple of extra ones as spares if I do like their sound. If you are open to buying from outside India then you might want to take a look at the KZ's.
If you want good sound, buy the Soundmagic ES18 (non mic version). But the ES18S(with mic) sound quality is nowhere near that of the non mic version.
I recently bought Tekfusion Twinwoofers M2 Headset from tekfusiontechnologies.com
They sound outstanding with my iPhone and their build quality and wire is solid. Thinking of doing a review of my views.
