Hi all,
Have few questions on blogspot. Not very good at CSS/XML hence unable to modify the template.
1 - One of the template has URL at the bottom which needs to be removed. When XML file is opened, I cant see the URL, however I can see other items of footer (e.g. Copyright xyz)
Bottom code of XML shows grabbled characters, Does it mean code is encrypted ? How to remove this URL ?
2 - Can any one suggest how to format posts with good formatting styles like quotes, paragraph inside a box etc ? Google search gave only few useful results.
3 - Is it possible to host a blog on custom domain while main site is already there ? This is bit complicated, here is the situation.
Main site e.g. www.xyz.com is hosted on blogspot using custom domain & it will be always static (displays products of a company), now company likes to start blog too with daily 1-2 posts.
Is it possible to have something like blog.xyz.com using custom domain ? If yes how to do it.
