Which one and does it work without lag?Yes, i did got a cheap one from Amazon.
Should not cause any issues afaik. Bt 5.0 features won't apply. Suggest u order it and if it doesn't meet your purpose then u can return it in a day or 2.Headphones are bt 5.0 , if usb is 4.0 will it be an issue? I have an generic one but that's causing lag. Same Headphones work fine on laptop.
Hey there are already a few recommendations in the comments above.Any suggestions for Bluetooth 5.0 USB dongle to connect Headphones with BT 5.0 please.
Thanks. Can you repost the recommendations for "Bluetooth 5.0 USB dongle" from the comments above please.Hey there are already a few recommendations in the comments above.
Thanks. I didn't see this in comments above. Need to get my eyes tested.Zither USB Bluetooth Adapter for PC 5.0 Bluetooth Dongle Receiver Support Windows 10/8.1/8 for Desktop, Laptop, Mouse, Keyboard, Printers, Headsets, Speakers, PS4/ Xbox Controllers : Amazon.in: Computers & Accessories
Zither USB Bluetooth Adapter for PC 5.0 Bluetooth Dongle Receiver Support Windows 10/8.1/8 for Desktop, Laptop, Mouse, Keyboard, Printers, Headsets, Speakers, PS4/ Xbox Controllers : Amazon.in: Computers & Accessorieswww.amazon.in
Yes, I'm currently using this with my Sony headphoneThanks. I didn't see this in comments above. Need to get my eyes tested.
Have you tested it yourself? Is it good to buy?
Thanks. Buying it. It is not amazon fulfilled. Did you buy it from (Gadgets2use)?Yes, I'm currently using this with my Sony headphone
Just checked, I got it from the same seller.Thanks. Buying it. It is not amazon fulfilled. Did you buy it from (Gadgets2use)?
Or should I wait for amazon fulfilled seller?
