coolcatric
Dear Friends,
Need your suggestion on buying a vacuum cleaner for home use. The requirements are as below:
1. To be used at a farm house in middle of a forest & mountainous terrain.
2. Should be able to clean dirt, insects & the likes.
3. Budget of 5K-6K INR, can increase if really needed.
4. I don't mind loud noise & electricity is not a problem here.
5. Should be able to clean dirt from windows, difficult access points & do the work of mopping as well.
Any suggestions ?
Thanks.
Any suggestions ?
Thanks.
