Budget 0-20k Cabinet+CPU+Mobo for raw processing power PC
J!gn3$h
Active Member
50
23
26
Questions
  1. What is your budget?
    • 20K
    • RAM - Corsair Vengeance 1X8GB DDR4 2400Mhz
    • Monitor - LG 22MP68VQ-P Full HD LED Monitor
    • PSU - Antec VP650P 650 Watt
    • SSD - Samsung 850 EVO 250gb
    • Case Fan - Noctua PWM fan
    • Case/Cabinet - Compact ATX case. Nothing fancy.
    • CPU - AMD Ryzen
    • Motherboard - any compatible B450/A320 ATX motherboard
    • GPU - May or may not buy
    • Pune
    • Open to online purchase
    • Yes
    • Programming
    • Browsing
    • Desktop Processing
    • HTPC
    • Watching HD movies
    • No
    • Windows 10 64 bit
J!gn3$h
Active Member
50
23
26
Budget -23K
Processor -AMD Ryzen 5 2400G -13k
Motherboard -Asus Prime B450M-K -7
Cabinet -Antec P100 -3k
Total -23K
Thank you @bssunilreddy..
Is Ryzen 3rd generation worth the wait in case if I increase my budget and would like to opt for Ryzen 5 2600X (being hexa core)?
6pack
ex-Mod
Sep 19, 2005
7,724
1,643
302
launch is in mid 2019 - like april-june. when it comes to india it will be sep-oct or next year. will you wait that long?
bssunilreddy
Veteran
Mar 24, 2007
2,066
798
207
40
Nellore
plus.google.com
