chetansha
- Budget: 50-70 K
- Existing hardware setup: None.
- Components from the existing setup that you intend to keep: NA
- Components that you have in mind for your new PC: Intel i7 with 64 GB DDR4 memory, Gfx - Nvidia k600/620, Asus Motherboard
- Plans to upgrade in the future: Not for 3 years
- Places from where you will buy components along with your location: Online and Local stores
- Are you comfortable with buying secondhand components from the Erodov market? : No
- Intended use of the PC [gaming/office use/rendering/HD playback etc] : CAD / CAM /3D Max
- Brand preferences: Intel CPU / Asus Motherboard / Corsair Memory , cabinet - Corsair or CM, PSU Corsair or Seasonic
- Monitor resolution and size: 24" +
- Will you be overclocking your setup?: No
- Which OS will you use?:Windows 7/10
