All OS Charging iOS and Android over mi 18w 10000mah power bank on daily basis !
princeoo7
On a Journey called Life :P
Jun 10, 2010
1,261
53
86
Mumbai
Is their a problem to charge iPhone and Android device with mi power bank 2i 10000mah on daily basis instead of normal chargers ? Is it a good idea for phones and the power bank ?
nimod
Jan 7, 2013
617
354
102
I don't think it makes any difference from a Wall charger.
Both should be supplying same voltage/current. Source doesn't matter.
princeoo7
Jun 10, 2010
1,261
53
86
Mumbai
I was thinking about the power bank.
My main issue is that I only have one port free for charger and it's quite headache to charge one phone at a time. Power Bank supports 18w charging and smart charging so iPhone can be charge with 18w and other can be charge with 5w or what max value it have.
vaalkai
Active Member
104
44
41
Higher the amps you use for charging, lower is the battery life with respect to Li-ion. If you want the best out of your battery, charge it slow, keep it cool and always maintain your battery charge between 20 to 80%.
princeoo7
Jun 10, 2010
1,261
53
86
Mumbai
Normally I am charging it with wireless qi charger but still wanted to know if fast charging with mi power bank on daily basis is a good idea or not.
Harpy.eagle
May 22, 2008
710
66
117
This is correct.
Also charging through power bank is less efficient way of using electricity. So for same amount of charging your phone, u would be using more electricity, if that matters to you.
Powerbanks are not 100% efficient to output 100% of charge what was used for their own charging.
You can always use multipin sockets or multipin USB adapters to charge multiple devices at once. That would be better way of doing it, assuming you are using good quality chargers. Otherwise cheap chargers would harm batteries more than using powerbanks itself.
