PC Peripherals Config for 2D design/photo-editing - please help!
-D.Payne-
Apr 9, 2007
467
92
117
36
www.greatdrivingchallenge.com
Hey all,
I need a config with 2 Display alternatives, one high-end 24" and one 22".
This PC will be used 90% for design and photo-editing using applications like Adobe's Creative Suite and CorelDraw.
An good quality and VFM IPS display is a must.
Now standard template:
1. Q: What is your budget?
Rs. 40,000 and slightly flexible (upto 45k)
2. Q: What is your existing hardware configuration
None
3. Q: Which hardware will you be keeping?
None
4. Q: Which hardware component are you looking to buy
1. Display - 22-24" high quality display
5. Q: Where will you buy this hardware? (Online/City/TE Dealer)
Mumbai and Open to online purchase
6. Q: Would you consider buying a second hand hardware from the TE market
YES
7. Q: What is your intended use for this PC/hardware
Design and photo-editing
8. Q: What is your preferred monitor resolution for gaming and normal usage
Ideally, 1920x1080 but ok with 1680x1050
9. Q: Are you looking to overclock?
No
10. Q: Which operating system do you intend to use with this configuration?
Windows 7 64 bit
DarkAngel
Veteran
Apr 10, 2009
6,420
321
222
Processor: Athlon II X4 630 - 5.2k
Motherboard: Gigabyte 785GMT-UD2H - 5.6k
RAM: Kingston 4GB (2*2GB) DDRIII 1333MHz - 4.4k
GPU: Any entry level proffesional GPU like Nvidia Quadro FX380/ ATI Fire pro V3750 . Should cost about 8-9k~. Not sure of the prices and other entry level cards in the market. ATI Fire pro V3700 is priced at 90$. Not sure of price and availablity here.
HDD: WD Blue AAKS 500GB SATAII - 2.5k
Monitor: Dell S2209WA-15k(e-ips)
Cabinet: NZXT Gamma - 2.1k
SMPS: Gigabyte Superb 460W - 2.2k
Optical Drive: L.G. GH22NS30 SATA/Samsung SH-S22F SATA - 1.1k
Speakers: Altec Lansing BXR1121 - 1.1k
Keyboard+Mouse: Logitech Multimedia Combo - .7k
Total: 45-48k
asingh
Super Mod
Jun 13, 2009
6,520
1,270
303
New Delhi
@D.Payne:
1. You want 2 monitors in that budget..?
2. Would you not need a PRO-series GPU for your type of work.
foruamit2004
Jul 10, 2008
465
37
92
35
I guess any mid-range computer(good processor ++) will do the job. No need of any extra GFX, 785G chipset would be sufficient for almost anything except gaming. but for a dual monitor setup you would need an entry level GFX card.
sarang
Dec 22, 2005
1,689
48
62
@Joseph: Stick to Karthi's suggestion. The 2209WA is worth its salt.
-D.Payne-
Apr 9, 2007
467
92
117
36
Total: 45-48k
Thanks!
A few things:
- A pro GPU really isn't necessary for 2D work. There will be NO 3D/rendering work on this computer anytime.
- The AMD X4 II is a quad-core but it also has very very less on-chip cache (2MB IIRC). My current dual-core iC2D E8200 has 6MB, and I believe this makes a huge difference in Photoshop.
- The Dell 2209WA is exactly what I am looking for - thanks!
- An entry-level GFX card will/should be part of this config anyway
Any suggestions now that we have 3-5k more on the CPU part?
Thanks!
Payne
PS: Dual monitors are not necessary - at this stage. :)
