Budget 51-70k Config for After Effects Work
gurujee
Member
53
3
18
With my budget, I know I can't expect a lightening fast computer. All I want a balance config which can give me a balanced processing and rendering speed. If Ryzen 2 will be better than Intel 8th Gen, I will be willing to go for that also.
  • What is your budget?
    • 60k
  • What is your existing hardware configuration (component name - component brand and model)
    • NA
  • Which hardware will you be keeping (component name - component brand and model)
    • Monitor -24inch LG
    • UPS
    • Keyboard+Mouse
  • Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
    • Everything except monitor, keyboard & mouse
  • Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
    • Can increase Ram if required
  • Where will you buy this hardware? (Online/City/TE Dealer)
    • Bhubaneswar, Odisha
    • Open to online purchase
  • Would you consider buying a second hand hardware from the TE market
    • Yes
  • What is your intended use for this PC/hardware
    • After Effects
    • Photoshop
    • Indesign
    • Premier
  • Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
    • No
  • If you will be playing games then which type of games will you be playing?
    • NO
  • What is your preferred monitor resolution for gaming and normal usage
    1. 1920x080
  • Are you looking to overclock?
    • No
  • Which operating system do you intend to use with this configuration?
    • Windows 7 64 bit
