Cooler Master, the industry’s leading provider of High-end Chassis, Thermal solutions and Mobile accessories today announces the launch of its most innovative chassis to date, the HAF XB (window version). Combining the superior cooling prowess of our HAF series with the compactness of a TestBench, the HAF XB packs a mean punch! Whether you are an enthusiast, an overclocker or a LAN party goer, the HAF XB will appeal to all courtesy its excellent set of features, stellar performance and an equally amazing price.
Innovative Design
HAF XB’s innovative form factor sets a new benchmark offering enormous space and unlimited flexibility in a compact LAN box. The HAF XB offers everything that you associate with CM’s HAF range of chassis – rugged looks, astonishing airflow, modular features, etc. It’s all there and in spades! The top panel gets an acrylic window so you can show-off your rig in style! The HAF XB supports two 120mm fans in the front, a large 200mm on the top and a 120mm and two 80mm fans on the rear panel enabling excellent ventilation. Strategically placed cable tie areas make cable routing effortless, reduce clutter and improve ventilation. Steel reinforced grab handles on side panels make it easy to move the box around during LAN parties.
Overclocker Friendly
One of the key features of the HAF XB is the way in which it seamlessly transforms into a TestBench for overclockers. A simple removable motherboard tray makes swapping hardware easy and painless. There is enough room to accommodate LN apparatus if that’s your game! The seven expansion slots means it supports triple SLI/CrossFire and has two X-Dock with support for 2.5†SSDs or 3.5†HDDs. The front panel I/O has two USB 3.0 ports for blazing fast data transfer.
The HAF XB (window version) is priced at an MRP of Rs 8,499/- and carries one year warranty. The product is available ex-stock and will be distributed by Acro Engineering Company across India.
Source: Press Release
