Budget 0-20k CPU+Mobo+RAM for Basic PC
HackerX
Member
68
0
17
Digital World
  1. What is your budget?
    • 15K
    • CPU - Intel G30
    • Motherboard - Dead
    • GPU - AMD 7750 1Gb
    • RAM - 4GB DDR3 1333
    • Monitor - Dell 22" 1080P
    • PSU - Antec VP550
    • 1TB HDD
    • PSU
    • Case
    • HDD
    • CPU - AMD RYZEN 3 2200G APU
    • Motherboard - ASROCK A320M HDV Motherboard
    • RAM - CORSAIR CMK8GX4M1D3000C16
    • Yes,
    • AmazonIN on EMI
    • No
    • Gaming(Old Games like Witcher 3 @720P)
    • Browsing
    • Desktop Processing
    • HTPC
    • Download rig, 24x7 operation
    • Watching HD movies, 10bit Anime etc
    • Other Basic things too
    • I heard the after sales service in India is pathetic. Yes we all know India is a pathetic place too.
    • Only Old Games.
    1. Gaming - 1280x720 for 3D and 1920x1080 for 2.5D
    2. Desktop - 1920x1080
    • No
    • Windows 10 or 7 64 bit
HackerX
Member
68
0
17
Digital World
Thank both of you guys.
So finally CPU or APU ?
HD7750 will be used.
No planning buy GPU soon.
If CPU then the chosen Mobo will be OK ?
Marcus Fenix
Veteran
Nov 22, 2010
1,347
515
152
Kolkata
The mobo is okay for the budget. Or you can allocate the 2.5k saved by going to 1200 to upgrade the mobo to a B450 chipset one
HackerX
Member
68
0
17
Digital World
How much fps will increase in game if I spend 2.5K extra on B450 mobo ?
Just tell me the gaming performance difference @720P for both of following systems.
Note that there will be NO OC at all.
AMD RYZEN 3 1200 + ASROCK A320M HDV + CORSAIR CMK8GX4M1D3000C16 + HD7750 1GB
or
AMD RYZEN 3 1200 + MSI B450M PRO-M2 + CORSAIR CMK8GX4M1D3000C16 + HD7750 1GB
Marcus Fenix
Veteran
Nov 22, 2010
1,347
515
152
Kolkata
There will be no FPS difference except for the fact that future upgrade path will be a bit restricted with the A320 boards in terms of I/O.
Furthermore the A320 boards being the lowest end of the budget spectrum will have lower quality capacitors which are one of the major reasons for the low life expectancy of cheaper boards.
Michael Simeonovitch
Just another poor guy
Veteran
Jul 17, 2012
1,048
598
151
or
Things are not that simple in the PC building world, mate.
the A320 board has 2 RAM slots. B450 has 4.
The a320 is not an overclockable board, the b450 is.
There is no wifi on the a320, means you will have to use a LAN cable, the b450 has o such issues.
The 450 boards have better inbuilt audio setups (incase you are a music pro, who cares about sound quality) etc etc.
Also more PCIe slots, for, idk, more nvme SSDs.
a B450 will be more future proof.
But I built my rig with A320, but thats because I knew what I was getting into.
HackerX
Member
68
0
17
Digital World
Only concentraingc at present instead future. No need WiFi, don't have LAN, NO OC, two RAM Slots enough etc. Now just tell the real story of capacitors ? B450 capacitors live how many more Days compare to 320M ?
Marcus Fenix
Veteran
Nov 22, 2010
1,347
515
152
Kolkata
That kind of definitive number of days will vary from user to user since B450/A320 mobos are not that old. I am guessing you're a student and not looking to use this config in the long run. If you're okay with that then you can definitely go with A320 and save some moolah.
vyral_143
Jarvis
Super Mod
Nov 28, 2011
3,330
1,454
207
香港
This should be able to play Witcher 3 at 720p with low settings. But newer games would struggle. If you can think of getting another GFX card in near future, opt for Ryzen 3 1200. If not, get Ryzen 3 2200G and fast (3000/3200MHz) RAM.
HackerX
Member
68
0
17
Digital World
Then it will be R3 1200 and Asrock 320M.
But 2x4GB or 1x8GB RAM ?
No RAM upgrade in future but may be GPU.
Thank you very much! :)
HackerX
Member
68
0
17
Digital World
Do we need to update BIOS to support R3 1200 or 2200G ?
At 4K Price which A320 should I chose ? Asrock or Asus or Gigabyte or MSI ?
Which 2x4GB of 3200MHz available at near 5K Price ?
Without any GPU R3 1200 show no display(totally Black Screen) ?
HackerX
Member
68
0
17
Digital World
Thank you!
I would have end up in trouble if I bought before your reply. There is no way I can do BIOS update by myself. What I do now ? Intel are very expensive option currently.
