cellar_door
- What is your budget?
- 30K. Willing to stretch a little if its worth it
- CPU - Intel E6350
- Motherboard - Some gigabyte one, not sure of the exact model
- GPU - NV 650 (will be keeping this)
- RAM - Transcend 2X2GB DDR3
- Monitor - Dell U2310 (keeping this as well)
- PSU - Dont remember exactly but wont be keeping it
- (please mention the rest in above format)
- Keyboard and mouse
- CPU - AMD 8320
- Motherboard - any compatible motherboard
- HDD - WD 1TB Blue
- PSU - Will be getting a 760 or equivalent sometime mid next year so suggest something 600W ish.
- RAM - 4 GB
- Cabinet - Not sure
- No upgrades anytime soon
- Delhi
- No
- Gaming
- None
- Pretty much everything
- Gaming - 1080/720
- Desktop - 1080
- No
- Windows 8
