Questions
- What is your budget?
- Flexible. Budget is not a strict limit but I don't want to throw money away either.
- CPU - AMD Athlon X2 3600
- Motherboard - some Jetway Mobo
- GPU - onboard
- RAM - Kingston 2X1GB PC6400
- Monitor - Viewsonic 19"
- PSU - VIP Gold 400
- Cabinet - Zebronics Bijli?
- All except CPU, Mobo, RAM and perhaps PSU
- CPU - please suggest (Pentium, i3, i5, AMD?)
- Motherboard - any compatible motherboard with onboard GPU (CPU/Mobo)
- RAM - 8 GB
- PSU - A good reliable PSU which is reasonably priced
- SSD - 128 GB
- Final
- Mumbai, Pune
- Open to online purchase
- I might consider if not too old and the deal is sweet
- Browsing
- Desktop Processing
- MS Office
- Might run a VM
- None
- Certainly no games now or in the future
- Desktop - 1440x900 could be higher in future
- Definitely No
- Windows 8 64 bit (Win 10 in future)
