CryENGINEâ„¢ 2 Specifications
Polybumpâ„¢ 2: Polybumpâ„¢ 2 can be used as either as a standalone utility, or fully integrated with other tools such as 3DS Maxâ„¢. This tool creates a high quality surface description that allows quick extraction of surface features like normal maps (tangent-space or object-space), displacement maps, unoccluded area direction, accessibility and other properties. The extracted information can be used to render Low poly models with surface detail almost making them look like the high-poly models but it will render much faster. The data is stored in a intermediate file format so it can be exported in different ways without doing the computation again. Very high polygon counts (e.g. 10 million triangles:clap: ) are processed quite quickly.
Next Generation Real-Time Renderer: Our renderer provides seamless support for both indoor and outdoor environments on DirectX9 and 10, as well as support for next generation consoles such as the Xbox360 and PS3 (under development):mad:
Real Time Lighting and Dynamic Soft Shadows: CryENGINEâ„¢ 2 features natural looking light sources, and creates soft shadows that dynamically respond to natural movements. It includes high-resolution, perspective correct and volumetric smooth-shadow implementations
Volumetric, Layer and View Distance Fogging: Create clouds or fog banks which can hug the ground and realistically reduce both visibility and contrast, and properly interact with both dynamic lights and shadows, add depth and dimension to a landscape by reducing scene contrast and clarity for distant landmarks
Terrain 2.5D Ambient Occlusion Maps: On a per pixel level, approximates the amount of ambient (fill) light reaching an object (static or dynamic) depending on the amount of ambient occlusion created by the surrounding foliage and structures.:eek:hyeah:
Normal Maps and Parallax Occlusion Maps: Normal maps are used to project the contour details of a highly detailed object onto a low polygon model by using a high frequency compressed (3DC/BC5) texture in place of the polygon’s surface normal in lighting calculations. CryEngine2 also supports parallax occlusion mapping to give a greater sense of depth to a surface texture applied to a polygon, such as could be used to realistically emphasize the relief surface structure of a brick wall, for example.
Real Time Ambient Maps: Pre-calculate the amount of ambient (fill) light which will be applied to indoor surfaces, to improve the quality of lighting when applying real-time per-pixel lighting and shadows. This means the current light position and color can be dynamically added to the fill light intensity applied to illuminate surfaces in interior spaces.
Subsurface Scattering: Simulates the diffusion and diffraction of light transmitted through translucent objects, like ice and jade; it can also be used to create natural looking skin or vegetation.
Eye Adaptation & High Dynamic Range (HDR) Lighting: Eye Adaptation is used to simulate the human eye’s adaptation to sudden or extreme changes in lighting conditions, like dark indoor environments suddenly transitioning to bright sunny outdoor environments, while HDR allows scenes with extreme brightness and contrast ranges to be more realistically rendered.
Motion Blur & Depth of Field: Motion Blur is used to simulate the visual effect of using a slow shutter speed when tracking fast moving objects or making quick camera movements. Blur can be applied both to individual objects (object based motion blur), and/or to an entire scene (screen based motion blur), while Depth of Field can be used to focus the viewer’s eye on a nearby object while subtly blurring objects in front or behind the point of focus.
Light Beams & Shafts: These are used to create visually stunning light beams and shadows when light intersects with solid or highly detailed geometry, and can generate “godray†effects under water.
High Quality 3D Ocean Technology: Dynamically modifies the ocean surface based on wind and wave direction, generating shoreline soft-clipping breakers automatically where the ocean meets the shore, depending on the shoreline contour and ocean depth, while our caustic simulation creates realistic looking moving shadows and highlights in underwater environments.
Advanced Shader Technology: A script system used to combine textures and math in different ways to create unique effects such as cloaked, wet, muddy, and/or frozen surfaces which can be layered together and combined with more basic shaders such as metallic and glassy and other visual effects. Supports real time per-pixel lighting, bumpy reflections, refractions, volumetric glow effects, animated textures, transparent computer displays, windows, bullet holes, and shinny surfaces. Included are many unique new shaders which take advantage of the efficiencies of the unified shader architecture of DirectX 10.
Terrain LOD Management Feature: This feature allows optimal usage of CPU and memory to display closer objects and terrain at a fine level of detail while enabling long view distances of over 8 kilometers.
Integrated Multi-threaded Physics Engine: Can be applied to almost everything in a level, including trees and vegetation, to realistically model reactions to forces like wind currents, explosions, gravity, friction and collisions with other objects, without the need of specialized coprocessing hardware. Also allows for character to ragdoll and ragdoll to character transitions.
Advanced Rope Physics: Bendable vegetation which responds to wind, rain or character movement, realistically interactive rope bridges, and physically driven creature tentacle animations are just some of the uses to which we’ve put our rope physics technology.
Interactive and Destructible Environments: Dynamically physicallize (using previously defined breaking or shattering characteristics) any arbitrary environmental object or shape, in order to destroy buildings, trees, or other objects, and then further interact with the resulting pieces.
Character Animation System: Our new character animation system considerably advances the state of the art in real-time human, model and vehicle animation. A fully integrated character editor allows animations to be previewed inside of CryENGINE Sandbox2, while our extremely powerful animation graph allows an animator to visually define the animation states of a character, and the allowable transitions between those states.
Character Individualisation System: The character pipeline uses a robust character attachment system which allows for attachment of skinned, animated, or physicallized attachments to the skeleton or polygonal faces of a character, to the extent you can even replace entire body parts such as heads, hands, or upper and lower body. A hardware based shape deformation system allows flexible variation of the character meshes. The system supports manually and even procedurally generated examples to ensure a small memory footprint. An additional variation system based on shaders is use for dirt, decals for clothes, and camouflage shaders for the skin.
Parametric Skeletal Animation: By blending example-motions based on user-defined parameters, we obtain responsive interactive control over a character with a focus on believability and the ability to adapt automatically and naturally to the changing circumstances of a game environment. This enables the character to travel at different speeds, follow paths where the direction changes smoothly or suddenly, move uphill or downhill, dynamically blend in varying amounts of hit reaction animation, and/or change the style of locomotion.
Procedural Motion Warping: Procedural algorithms like CCD-IK, analytic IK, example-based IK or physical simulations are used to augment pre-authored animations. All procedural methods have in common that a computer procedurally follows the steps in an algorithm to generate artificial motions. To avoid the typical computer-generated look when combining artificial and captured animations, we use a warping technique that can preserve the style and the content of the base motion, despite the transformations needed to comply with the constraints.
High Quality Animation Compression: Using our adaptive key frame compression technology, we can adjust the compression level to match the fidelity needed for any given animation while saving at least 90% of the RAM that would otherwise be consumed, without significant loss of motion fidelity.
One of my friend who works in a EA tech support call center forwarded me this PDF file format of Cryengine 2 spec wait for tomorow for the Cryengine 2 Sandbox PDF will post it tomorow:cool2:
the PDF is available on gamespot or IGN.com i think.
its just a 19 pg pdf whch kinda helps promote developing companies to buy the cryengine 2 and no he wont get into trouble.
Anish said:
Though posting the Sandbox can get him into trouble ;)
Sandbox 2 is for promotional use too there is nothing illegal about the information the pdf contains screenshots and all other stuff its ment for promotional purpose
