Audio DAC for Swans M10
labakkudas
I bought a pair of Swans M10 speakers from hifinage in August and have been enjoying them ever since. I want to add a DAC to my setup since I feel my laptop audio is not good enough for the speakers.
Any suggestions? My budget is under Rs. 10000 and I'm open to importing it if need be.
I doubt swans M10 will be resolving enough to require DAC upgrade.
In any case ,you could try from something portable like Fiio E10K, audioengine D1, will serve as good HP amp too.
I run my M10's with the Essence STX DAC, so if you're really curious, i can do an A/B test using that DAC vs my motherboards onboard chip (ALC 892) if i do get the time over the weekend.
