- Q: What is your budget?
- 45-50K
- 45-50K
- Q: What is your existing hardware configuration (component name - component brand and model)
- CPU - Intel E4600
- Motherboard - Abit IP35e
- GPU - Palit 9800GT 512MB DDR3
- RAM - G.Skill PI Black 2x2GB 800MHz
- Monitor - Viewsonic VA1912w
- SMPS - Circle Raw power 550watt
- CPU - Intel E4600
- Q: Which hardware will you be keeping (component name - component brand and model)
- SMPS - Circle Raw Power 550watt (if I can use)
- Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
- CPU - AMD Phenom II X4 955 Black Edition Deneb 3.4GHz
- Motherboard - Please suggest me good, I'm bad in selecting motherboard.
- GPU - HD 6770, HD 6790 ? Don't know much about brand like HIS.
- RAM - G.Skill Sniper 2x4GB 1600MHz DDR3 (That's so cheap out there, I doubt if it is any good)
- Harddisk - Seagate Barracuda 7200.12 ST31000524AS 1TB (already have 1TB with me)
- Monitor : BenQ G2222HDL
- Keyboard and Mouse : RAZER Arctosa Silver on Black KB + Razer DeathAdder (4k total)
- Cabinet : NZXT Guardian?
- Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
- Not changing anything, atleast for a year
- Q: Where will you buy this hardware? (Online/City/TE Dealer)
- Online purchase
- Local shops (if available)
- Online purchase
- Q: Would you consider buying a second hand hardware from the TE market
- Yes
- Yes
- Q: What is your intended use for this PC/hardware
- Gaming
- Internet Surf
- Light rendering (videos)
- Movies, Music.
- Programming (Java, Android, Web application)
- Gaming
- Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
- Not so far
- Not so far
- Q: If you will be playing games then which type of games will you be playing?
- BF3, if this config supports
- TF2, CS:S
- Q: What is your preferred monitor resolution for gaming and normal usage
- Default monitor's resulution for casual use.
- For gaming, some lower resolution.
- Q: Are you looking to overclock?
- Not planned but may overclock in future.
- Q: Which operating system do you intend to use with this configuration?
- Windows 7 64 bit
- Windows 8
- Linux - Ubuntu
- Windows 7 64 bit
I'll be upgrading it in next 2 weeks.
