nac
I see many buying DSLR or wanted to buy one without knowing much about it or are is it status symbol? Most of the people using their mobile phone for making and receiving calls, yet they spend 30+ grand for a smart phone!!! Does DSLR becoming like that? There may be tons of justifcation, probably I will never get the depth of them.
Coming to the topic... DSLR (Read, interchangeable lens camera)
You looooveee to take photographs. You're shooting with your compact (or mobile) camera, thinking of picking it up as a hobby. And you see this friend of yours showing off his DSLR. You think that DSLR will help you take better photographs. You know... your camera is as good as you get. In fact, it may likely to produce worse photos than what you have been capturing with your compact camera if you don't know how to use a DSLR.
Like every product, DSLR has its own drawbacks. See if you can live with these...
DSLR has more buttons and knobs around the camera. Ofcourse, it's much useful for professional photographers. But is it a must-have for a beginner? I don't think so.
Maintaining a DSLR is like owning a ride. You keep it under regular check, it works best. If not, it's likely to cost more to fix the problem when that happens.
Owning and maintaining a system is expensive. If you want great results, you need quality glass. For different purpose, you need different lenses. You can very well slap an all-in-one 18-300 or even 18-500 (if it comes in future
), but that defeats the purpose of DSLR and the quality of consumer super-zoom optics is not great.
DSLR is bulky and heavy. It's not as portable as compact camera. You can't keep it in your shirt pocket or in your trouser pocket. Unless it's for professional work, taking it everywhere with you is not convenient.
DSLR is little complex to use. Though it's not a rocket science, it needs some effort from the user to make good use of DSLR. Yeah, you can put it in Auto mode, but again that defeats the purpose of DSLR.
Of course, if your skill or work demands a DSLR, go ahead and buy one and use it to its extreme limits. But if you're like most people, shooting when the spirit hits you, or for home use, you're better off with a compact camera.
