Sudarshan_SMD
Hi,
A month back I went for an trek with my Panasonic Lumix LZ8. The environment was all moist as most of the trek was through forest and mountains. After I came back home from trek, I noticed some spots on images that were taken after trek. I tried to clean lens with cloth, but it didn't helped. So camera sensor is the culprit.
Here are some pics on blank surface to show spots:
0x Zoom
5x zoom
Today I was trying to take a pic with camera mounted on cheapo DealExtreme tripod and suddenly tripod head broke off and camera dropped on parapet wall of my balcony. I somehow got hold of the camera and saved it from fall onto ground.
Then I noticed that due the impact of camera fall, dust/spots on camera senor was reduced considerably.
Here is the condition for now:
0x zoom
5x zoom
The question is:
Where should I take my camera to?
Should I take it to Panasonic official service center?
Is this(dust on sensor) covered under warranty?
Or is there any other way of cleaning the sensor?
PS: Camera is 2 years old and it still has 1 year warranty left.
I always take good care of my camera, but somehow dust got inside it.
What measures can you suggest so that this won't happen again?
Noise problem:
I did noticed that before todays fall, when camera sensor has got dust on it, noise in pics was very high. Even at daylight there was some noise and it became worst at low light.
Now they noise is no more in my pics and Aperture priority mode is working like charm which was screwed when sensor had dust.
Does dust on sensor affect camera performance? or It is just my illusion?
0x Zoom
5x zoom
0x zoom
5x zoom
The question is:
Noise problem:
