Budget 21-30k Ex CS 1.6 Player needs a decent build.
Vzuwow
Recruit
  1. What is your budget?
    • INR 25,000
    • N/A
    • N/A
    • CPU - Ryzen 2200G
    • Motherboard - Gigabyte A320 (Im getting B350 for INR 6000, second hand, from a friend. Is it worth?)
    • GPU - N/A
    • PSU - 450W Corsair
    • HDD - WD 1TB
    • RAM - Corsair Vengeance or HyperX fury 8GB Stick
    • Cabinet - Zebronics Bijli 2
    • Monitor - LG 22MP68VQ ( Already purchased for INR 8100 from Amazon)
    • Final
    • Offline - Mumbai Lamington Road
    • Yes
    • Gaming
    • Browsing
    • Desktop Processing
    • Downloads
    • Watching HD movies
    • Open to all.
    • CS GO
    1. No Preference
    • Maybe. Can take as Yes.
    • Windows 10 32/64 bit
I have a
2200G
2400 MhZ DDR4 x 2
240 GB SSD (No HDD)
Built sorely for CSGO.
Ask if you want any specific information.
Finalized. Any more tweaks? B350 will take my budget to 31000 while with A320 while be around 27000
I would go for the B350 as the A320 is the most basic kit for AM4. BTW you were getting the B350@6k right? If a new A320 is 4.4k odd how come its 31k (B350)vs 26k(A320). Did you decide to go for a new mobo?
If so then I can see that B450 is available at 1k lesser than the Gaming 3 which uses older gen chipset although the Gaming 3 a starter premium mobo.
https://mdcomputers.in/gigabyte-b450m-ds3h.html
https://mdcomputers.in/amd-platform...bility=1/sort=p.sort_order/order=ASC/limit=16
Yes, 31K if i purchase a New B350 which will cost me INR 8400. (A320 Costs INR 4376).
I dont know why im not much inclined towards going for a used one but anyway i will go for either B350 and hopefully if things work out B450.
Instead of spending 8.4K on B350, spend 7K on B450 based mobo as linked above.
Also can you buy better PSU ? VS series from Corsair is near crap.
Done
1 Processor AMD RYZEN 3 2200G PROCESSOR WITH RADEON VEGA 8 GRAPHICS 8293
2 Mother Board ASUS PRIME B450M-K Motherboard 7519
3 RAM HyperX FURY Series 4GB 2400MHz DDR4 Memory HX424C15FB/4 x 2 6100
4 PSU Antec VP500P 2499
5 HDD WESTERN DIGITAL CAVIAR BLUE 1TB INTERNAL HARD DRIVE WD10EZEX 3250
6 Cabinet CORSAIR CARBIDE SERIES 100R MID-TOWER CASE CC-9011075-WW 2816
Gran Total 30477
I have a Asus Crosshair VI Hero paired with a Ryzen 1700 and based on that experience i would suggest you go for Gigabyte instead of Asus.
The software support of Asus in terms of BIOS/drivers etc. is pretty lethargic compared to Gigabyte.
Since 4 GB is a bit low plan to add another 4 GB stick of the same model sometime in the future.
If this is your primary machine then go for the WD Blue 1TB. If this is not your primary rig I would suggest getting an M.2 SSD as your OS drive which is nearly the same price.
https://mdcomputers.in/western-digital-green-240gb-m-2-wds240g2g0b.html
I am suggesting this as you can add mechanical drives to the PC pretty easily later on but its a bit problematic to switch the existing OS drive from a HDD to a SSD later on without a full reinstall.
I have mentioned Ram 4gb x 2. Total 8 GB.
Finally going tomorrow to buy the components.
Have made some last changes as per the advice provided here:
1 Processor AMD RYZEN 3 2200G PROCESSOR WITH RADEON VEGA 8 GRAPHICS INR 8293
2 Mother Board Gigabyte B450 AORUS M AMD AM4 Motherboard INR 8550
3 RAM HyperX FURY Series 4GB 2400MHz DDR4 Memory HX424C15FB/4 x 2 INR 6100
5 HDD WESTERN DIGITAL CAVIAR BLUE 1TB INTERNAL HARD DRIVE WD10EZEX INR 3250
6 Cabinet CORSAIR CARBIDE SERIES 100R MID-TOWER CASE CC-9011075-WW INR 2816
7 SSD Western Digital 250GB M.2 Internal Solid State Drive (S250G2B0B) INR 4901
Gran Total INR 36409
Always install the M.2 on the motherboard before installing anything else. The tiny screw for the M.2 is a cast iron b**ch.
Since you have decided to go for the SSD+HDD combo just a tiny suggestion. Go for the Samsung 860 Evo which is a far better SSD than the WD ones for a Rs 800 premium over the WD SSD.
https://mdcomputers.in/samsung-860-evo-mz-n6e250bw.html
The WD one will be good as well but Samsung is the market leader in SSDs right now.
I think i need to add GPU as well since when i play CS GO in my free time, it lags a lot when someone smokes or when there are a lot of people playing.
Can anyone suggest a good GPU for the above mentioned configuration? Budget 5K-8K
Not sure if this would work. You have one option in that price range nVidia GT1030.
https://www.userbenchmark.com/PCGam...-Strike--Global-Offensive/3680/283726.0.0.0.0
https://mdcomputers.in/asus-gt-1030-2gb-gddr5-phoenix-oc-ph-gt1030-o2g.html
I would suggest saving up a bit more and go for the 1050 Ti
https://mdcomputers.in/asus-ph-gtx1050ti-4g.html
I was playing on HIGH settings. Got the settings from one of the best players and they say LOW settings are enough. Voila No lagging now.
