As the chennai heat becomes unbearable, our V-guard double boost unable to cope up with 130V available at the mains. Also the stabilizer cant start the compressor when the voltage is below 160V but it manages to keep the AC alive till 130V is the compressor is running. Sometimes I used to run the fan in inverter mode to get some air from the fan. Enough is enough, I am in search of extra wide input range a.k.a triple boost stabilizer. I asked a local electrician and he recommended a brand called "Spark" which can run the A/C till 120V. Also triple boost mean more loss of power which negates 5* effieciency of the A/C. Anyway I am least bothered on that now. On searching over the www I have found there are some automatic stabilizers come with Toroidal transformer with 110~120V range. Anyone have experience of purevolt products?
AUTOMATIC VOLTAGE STABILIZER, AUTOMATIC POWER REGULATORS, AUTOMATIC POWER CONTROLLERS, MANUFACTURER, EXPORTER, SUPPLIER, INDIA
Stabilizers - Products - Toroidal Urvi.in (Urvi Transformers Pvt. Ltd.)
Domestic Voltage Stabilizers - Digital Servo Stabilizers For Domestic Purpose, Automatic Voltage Stabilizers and Digital Voltage Stabilizers For Air Conditioners Manufacturer & Exporter
Logicstat.com - Automatic Voltage Stabilizers: Specifications
Regards,
Vijay
Regards,
Vijay
