Finding it difficult to learn Angular 2
raja_mastana
Apr 9, 2006
549
145
132
Any angular 2 programmers here? I have been trying to learn angular 2 for around 1 month (few hrs everyday, but not regularly). But, finding it difficult to understand - mainly things like the components inside components, property bindings, how the components communicate with each other etc. I have PHP/MySQL experience.
vishalrao
Global Moral Police
Veteran
Nov 10, 2007
4,616
703
202
Pune, India
I dunno if it follows this "MVC" pattern (model - view - controller) - maybe (if it does) you should also study about that design pattern - it might help to digest this stuff :)[DOUBLEPOST=1496836580][/DOUBLEPOST]Also, if you mention where you have been learning this from then maybe other folks can suggest other/better online/free resources to learn this.
Reactions: raja_mastana
raja_mastana
Apr 9, 2006
549
145
132
Thanks, I dont know about design pattern - will search about it.
I have been going through the Lynda angular2 essential training
meetdilip
Oct 9, 2011
668
106
81
Get the basics from YouTube. You can even try Angular 1 before heading to Angular 2. Makes it easy that way.
m-jeri
A Nobody.
Veteran
Jun 21, 2008
4,164
822
202
34
Eden Prairie\Trivandrum
I am a react guy. So cannot be of much help.
As far as I understand from others. No need to go through Angular 1 to Angular 2 if you are new. Unless you see yourself reworking existing frameworks as such. These are the people who wrote react btw. :). So I believe they are right.
But still, I would second the suggestion to understand MVC. Are you using ASP.NET Core and Angular?
raja_mastana
Apr 9, 2006
549
145
132
Thanks, even i heard that angular 1 is not required for learning angular 2.
No, I am not using ASP.NET, just angular.
vigilante
Nov 28, 2011
533
193
81
Pune
How much comfortable are you with html, javascript and JQuery?
I've worked on Angular 1 and just recently trying my hand at Angular 2. They are quite different. Read some tutorials on how to start thinking in angular. For me at first it was difficult to let go of my Jquery thought process.
Pluralsight has some really great tutorials by Deborah Kurata and John Papa (you won't need to know angular 1). It's a paid service but my organisation has a subscription.
You can use the 10 day free trial and one of these courses should really help you get started.
P.S. The tutorials use typescript ans some OOP knowledge would come in handy.
raja_mastana
Apr 9, 2006
549
145
132
Thanks vigilante, I just went through 30 minutes of Deborahs tutorials and it seems much more detailed and beginner friendly.
I have created apps on HTML, PHP & MySQL using Bootstrap framework, but not so much on Javascript and JQuery.
Angular seems have a lot of new things for me like Single Page applications and related concepts like components, modules, their metadata, selectors, bindings etc, which is why it was/is going bouncer
I just need to spend more time going through tutorials like these
vigilante
Nov 28, 2011
533
193
81
Pune
Welcome. Just keep doing the hands-on simultaneously with the tutorials and you should be able to get hang of the concept. Just think of it as adding behaviour to html using script.
The in-built directives are quite powerful and help you accomplish a lot with minimal code.
Party Monger
Veteran
Jul 15, 2007
4,528
923
201
While there are so many tutorials on programming in stuff like Angular etc, theres a real lack of resources (paid or free) that take you step by step and also make you practice by making practical small apps to implement concepts and give you an idea. Most of these are high level theory concept explanations only and making the jump from that to practical concepts is a huge jump for newbies. If someone knows any resources, do share..
raja_mastana
Apr 9, 2006
549
145
132
Totally agree with you. When I was learning PHP, I was going through training videos from one of the famous sites, but honestly it was very boring to sit through them, (though it was very good and accurate material). I then found a video tutorial which focused on building a very simple registration and login system with bootstrap framework. That was the most practical video tutorial i ever saw (simple and easy to understand), and I could use that as a foundation, to build my app on top of it. I did not need any tutorials from there on, i was able to google whenever I got stuck and resolve it (stackoverflow to the rescue mostly)
Akil
Member
3
2
8
Hi,
I have built angular 1 apps and recently picked up angular 2, Its a different beast, So i suggest you first start with learning TypeScript, after you are reasonably familar with TypeScript, google's codelabs are awesome, you can find the basics of angular codelab at https://codelabs.developers.google.com/codelabs/angular-codelab/#0 , i like the codelabs as the teach you by actually building stuff step by step.
Also my company has a course wherein we make students learn and experiment with various technologies, but that course is more suited towards students who are in or just recently passed engineering.
