ajackson
I'm looking for guidance on a FreeNAS build. For starters, I need recommendation on motherboard and cabinet with 6 to 8 bays. I plan to use the Intel G4560 for the CPU, but open to better recommendations. I have been reading up about Intel Xeon, but not sure where to even start. Also, PSU and RAM recommendations too please.
I have a Synology 918+ on the way, so the new NAS will act more for backups of the Synology.
Let me know if I’m missing or overlooking something.
Thanks!
Thanks!
- What is your budget?
- Up to 100K, but lesser the better.
- NA.
- NA.
- Intel G4560.
- Intel Xeon.
- Will be final for a while.
- Hyderabad.
- Online.
- Yes.
- NAS and backups.
- Prefer Intel.
- NA.
- NA.
- No.
- FreeNAS.
