[FS] - Leadtek 7900GS TDH Extreme 256MB DDR3
amigoatul
May 30, 2006
443
9
81
Rating - 100%
13   0   0
Hi ppl. Selling my Leadtek 7900GS TDU Extreme 256MB video card. Its a lil over 2 yrs old and has about 8 months warranty left. The card is working absolutely fine and can run most games at med to high settings at reasonable resolutions. Have the bill, the box & some accessories. Wud be gr8 for ppl looking for an SLI option.
Tech Specs -
Leadtek WinFast PX7900 GS TDH Extreme Technical Specifications
Graphics Engine
NVIDIA GeForce 7900 GS GPU
Stock 3D GPU clock = 520MHz
NVIDIA CineFX 4.0 Shading Engine
Vertex Shaders
Support for DX 9.0 Vertex Shader 3.0
Displacement Mapping
Vertex Frequency Stream Divider (Geometry Instancing)
Infinite length vertex programs (supported in hardware)
Pixel Shaders
Support for DX 9.0 Pixel Shader 3.0
Full pixel branching support
Multiple Render Targets (MRTs)
Infinite length pixel programs (supported in hardware)
Texturing Engine Features
Accelerated textures access
Up to 16 textures per rendering pass
Support for 16-bit and 32-bit floating point formats
Support for sRGB texture format for gamma textures
DirectX and S3TC texture compression
Full 128-bit FP Precision Graphics Pipeline
Native support for 32 / 64 / 128 bits per pixel rendering modes
64-Bit Texture Filtering and Blending
NVIDIA UltraShadow II Technology (accelerates shadow computations)
NVIDIA SLI Technology
NVIDIA Intellisample 4.0 Technology
16x Anisotropic Filtering
Adaptive Texture Filtering
Gamma-adjusted Rotated Grid Antialiasing
Transparent multisampling and supersampling modes
Fast antialiasing and compression performance
Loss-less Color, Texture and Z-Data Compression algorithms (in real time)
Fast Z-clear
Support for normal map compression
NVIDIA PureVideo Technology
Dedicated programmable on-chip video processor
MPEG-2 video encode and decode
High Definition H.264, MPEG-2 and WMV9 hardware decode acceleration (up to 1080i)
Post Processing Features
Spatial-Temporal De-Interlacing (adaptive)
NTSC 3:2 Pulldown / Bad Edit correction
PAL 2:2 Pulldown correction
High quality 4x5 video scaling and filtering
Microsoft Video Mixing Renderer (VMR)
Integrated HDTV output (with HDCP support)
Composited Desktop Hardware Engine (for Windows Longhorn)
Built for Windows Vista
Delivers best possible experience when running Windows Vista 3D graphical user interface
New OS supported by renowned NVIDIA Unified Driver Architecture (UDA) for maximum stability and reliability
NVIDIA PureVideo technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista
Advanced Video and Display Functionality
Dual 400MHz RAMDACs that support resolutions of 2048x1536@85Hz
Dual-link DVI capability to drive the industry's largest and highest resolution digital flat panel displays up to 2560x1600
Integrated HDTV encoder provides analog TV-output (Component/Composite/S-Video) up to 1080i resolution
nView Multi-display Technology
NVIDIA Digital Vibrance Control (DVC) 3.0
Designed for PCI Express x16
Advanced thermal monitoring and thermal management
Graphics Memory
256-bit memory interface
256MB Graphics DDR3 SDRAM
Default clock rate of 700MHz (effective speed of 1400MHz DDR)
Display Capabilities
Dual-link DVI capability to drive displays of up to 2560x1600
Connectors
1 x mini-DIN connector (for Video-out)
2 x DVI-I connector (HDCP Ready)
Drivers & Software
Driver support for Microsoft Windows Vista/9x/ME/2000/XP/XP MCE/XP Pro x64, Linux and Macintosh OS (including OS X)
CyberLink Power DVD 6.0
Orb
SpellForce 2: Shadow Wars
Serious Sam II
Other Information
PCI Express x16 slot required
Dedicated 6-pin PCIe Molex power connector required (not shared or split)
Power supply rated for 400W or higher recommended by NVIDIA (500W PSU for SLI setup)
Prefer to sell it to local buyers just to avoid shipping. Can also ship if needed.
Reason for sale - Recently upgraded my video card.:)
Lowballers pls stay away. Donot crap if ur not interested in the purchase.
amigoatul
May 30, 2006
443
9
81
Rating - 100%
13   0   0
Alrite guys, id appreciate it if u guys cud pm me instead of crapping this thread.
Im willing to sell it for 3k. Less than that and id rather keep it n use it on ma old rig.
