FS : Modded SE K750i
SunnyBoi
Veteran
Jan 31, 2005
4,467
461
172
34
Bangalore
www.funenclave.com
Feedback: 34 / 0 / 0
Phone modded inti a W800i, changed all possible drivers, ahev patched the firmware, etc. have done all possible useful mods except putting in elf packs :)
Pastches installed :
remove java restriction
unlimited SMS
small fonts
FM without handsfree
sysgfx
menu : Iphone
sound : blackice wowII live + hyper PHF
camera : super cam driver 8.54
will give original hpm 70 handsfree ( one leg vut, can see in pic so have to use a rubber band ) and a top earphone one with one bud missing :ashamed: and one SRC200 ( the orange and white handsfree. has a white led so its easy to operate in dark :p
cards : sandisk 4GB fake + orig 64MB card
can load upto 2.8Ggigs properly on the card before it starts to act up.
with sysgfx, many icons are changed, incl battrey and signal ones, as well as file manager icons.
comes with orig box, data cable n charger, dont have pics of them atm.
adding lotsa pics :S
expecting 3600 for the whole thing. :)
will add more details tomo :S kinda in a hurry.
SunnyBoi
Veteran
Jan 31, 2005
4,467
461
172
34
Bangalore
www.funenclave.com
yup it works. infact many ppl remove the panel, solder a really thin copper wire to the 2nd pin ( i think) and hide itin the casing so that you have an internal antenna :p
rishabh.asthana
May 10, 2008
327
27
92
36
Feedback: 33 / 0 / 0
got the phone :) :) sunny bhai had to sit alone in ma room for some time all alone when i was off making ransom calls to his home ;) ...everything else went through smoothly :)
