Budget 0-20k FX8320, Asus M5A97 EVO R2.0 - need Graphic Card
Skyh3ck
199
12
81
Skynet
Hello
I have
AMD FX8320
Asus M5A97 EVO R2.0
I have two system i need one cheap basic graphic card, one id range gaming graphic card.
And if it makes more sense to buy a new IGP motherboard i will buy that one.
Please help.
Skyh3ck
199
12
81
Skynet
Thanks but in one system i want just a working card. And other system want a gaming card for mid range game.
For one system if I can just change the motherboard with IGP based one. Please help
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Hello
I have
AMD FX8320
Asus M5A97 EVO R2.0
Please help.
Sell of the AMD AM3 CPU and get Intel Pentium Gold CPU and compatible Mobo +RAM
Skyh3ck
199
12
81
Skynet
So I guess DDR 4 is mainstream now.
Ok so suggest me 2 or 3 option for Motherboard processor Ram
Option 1 rs 10000
Option 2 rs 15000
Option 3 rs 18 or 20000
I have cabinet, corsair's 450 PSU, full hd Dell monitor, keyboard mouse, 1 tb HDD, optical drive.
I only need the heart.. nono privacy and ram.. i. Thinking to put 8 GB ram
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Option 1 rs 10000
Option 2 rs 15000
Go with option 3 with some additions.
Budget -31.7K
AMD Ryzen 5 3500 - 11k
Mobo - Asrock B450 Pro4 - 6.8k
RAM - G.Skill RipJaws V 8GB DDR4 3200MHz - 2.8k (mdcomputers)
GPU -Zotac GT 1030 2GB DDR5 -5.7k
PSU - Antec VP550P Plus -3.1k
SSD -Western Digital Green 240GB M.2 SATA III -2.3k
Total - 31.7k
All above prices are taken from theitdepot.com except specified above.
PS: If you have Corsair VS Series PSU just ditch it because it has low end chinese capacitors only for asian markets. Just add the SSD and enjoy the speed.
Sell of the remaining CPU+Mobo+RAM+PSU which might fecth you 10k So as your present budget is 20k add this amount and get the above config. It will last another 5-6 years at the least.
https://www.theitdepot.com/
Skyh3ck
199
12
81
Skynet
Thanks brother..
Please give me a motherboard processor and Ram with inbuilt graphic motherboard.
As cheap as possible that can run moderate home and office apps like, ms office, excel, vlc player, ig it has inbuilt wifi that's great
chetansha
Veteran
Jun 30, 2007
1,827
737
202
Coimbatore
Thanks brother..
Ryzen series motherboard DO NOT HAVE inbuilt graphics.Only ryzen apu's have vega graphics ( 2200g, 2400g, 3200g, 3400g)
Skyh3ck
199
12
81
Skynet
Then what about Intel
I just need a working system
Motherboard processor and ram. Should be not very old released ..
Should be a good decent system without hitting too much in pocket
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Thanks brother..
Budget -27.4K (APU RIG)
AMD Ryzen 5 3400G - 12.9k
PSU - Antec VP450P Plus -2.6k
Total - 27.4k
Dont ever go withCorsair VS Series PSU's
Even Corsair CX Series are better and TX Series are superb.
chetansha
Veteran
Jun 30, 2007
1,827
737
202
Coimbatore
Total - 27.4k
For office rig 3200G is more than sufficient. I could play NFS on it too. Increase ram to 8gbx2 dual channel - gives better performance.
Crapmypants
Dec 13, 2014
862
336
101
if you need a basic graphics card, then consider the geforce 710(Rs. 2-3k) or the 1030 (Rs. 5-6k)
For the second system, what's your budget for the gpu?
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
The above config is much more future proof and will last for another 3-4 years at most.
Post automatically merged:
Budget -14K ( AMD Config)
CPU - AMD Ryzen 3 1200 - 5k
Mobo - Gigabyte B360M Gaming HD -5.5k
Total -13.3k
Budget -13K (Intel Config)
CPU - Intel Pentium Gold G5400 - 5k
Mobo - Asus Prime H310M-K -4.6k
Total -12.4k
All above prices are taken from vedantcomputers except RAM from mdcomputers.
Check this UserBenchmark once and decide for yourself:UserBenchmark: AMD Ryzen 3 1200 vs Intel Pentium Gold G5400
Skyh3ck
199
12
81
Skynet
0 - 5k
Ok may be today or tomorrow i will go and buy.
What other option i have.
What if i wish to increase processor budget little bit. What is next good option from AMD and INTEL
Processor -AMD RYZEN 3 2200G WITH RADEON RX VEGA 8 GRAPHICS PROCESSOR (upto 3.7 GHz / 4 MB Cache)
MB -ASUS EX-A320M-GAMING MOTHERBOARD
RAM -ADATA XPG GAMMIX D30 8GB (8GBX1) DDR4 3200MHZ RAM
how is this, will it be good for some light casual gaming like RTS, FPS etc.
will it work without graphic card or i need to buy one,
can i add graphic card and SSD and more RAM later if i wish to
and i have Corsair VS450, will it be compatible with it
Or
Does it make more sense to keep the FX8320 and Asus M5A97 and just buy a new low cost graphic card.
I am inclied towards buying new please suggest
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Or
Sell them and buy a new PC.
AM3 socket reached its EOL.
If your primary need is only browsing then keep FX8320 and add a low budget GPU like GT710 or GT1030.
Skyh3ck
199
12
81
Skynet
so if any AMD processor does not have "G" it means it is not having graphic capability, ???
in that case i have to buy a separate graphic card, even thouth the motherboard has DVI, HDMI port, it will not give any video output ??
Also you suggested earlier Ryzen 3 1200, does that have GPU inbuilt
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
No
AMD Ryzen 3 2200G has inbuilt GPU
But this needs DDR4 RAM which cost you 2.5k for 8GB
Again Mobo needs to be changed because socket changes from previous AM3 to AM4 on which Ryzen is built upon.
Crapmypants
Dec 13, 2014
862
336
101
This is correct. the dvi/hdmi ports are for the onboard graphics so if the cpu doesn't have one you will need a separate graphics card.
Yes you can add a more powerful graphics card later on even if there is an onboard gpu.
Ram also can be added later on, just make sure that the speed and timings of the ram match each other.
yes, the corsair vs450 will be compatible. Just don't overclock the shit out of everything and you'll be fine.
Skyh3ck
199
12
81
Skynet
why no one suggesting any Intel based config, are they not worth of money .
do all motherboard now has built in Wifi and Bluetooth so we dont have worry about adapter any more.
Which is the best chipset to club with AMD ryzen 2200G, so it gives some scope of upgrade in future
what is the diference between B450 and B350 which one is best, i guess price is not much differnce here
vyral_143
Jarvis
Section Mod
Nov 28, 2011
3,229
1,369
207
香港
If your current setup is getting things done, do not spend on upgrading it unnecessarily.
For 1 rig where you need GFX card just for display, get GT710 for 2.5K from PrimeABGB or look at TE market for used GT710 at 1.5K
For another rig, where you need casual gaming capability, get RX 580 from Vedant Computers for about 11K or looking at TE market RX 570 at 7.5-8K mark. If this rig is running Corsair VS450, I would suggest getting better PSU along with GPU.
Do your systems have SSDs for boot ?
