Good Quality Leather Belts
Discussion in 'General Talk' started by John4321, Mar 29, 2019.
  1. John4321
    John4321 Active Member
    Where can I get good quality leather belts in Mumbai for formal and casual both?
  2. nRiTeCh
    nRiTeCh If you can see the green dot, I'm online ;-)
    Veteran
    Dharavi. The purest, best and genuine.
  3. OP
    OP
    John4321
    there are many types of leather in Dharavi. Which is the best quality leather for belts which can last for a long term?
  4. vivek.krishnan
    vivek.krishnan If you cant see the green dot, I'm offline :P
    Veteran
    What should be the cost as well? I mean, least one gets ripped off....
  5. blr_p
    blr_p Well-Known Member
    Veteran
    How good the leather is something i'd like to know as well. This is one of those areas where a lot is done to fool people.
    Many years ago i was in Florence, Italy. They have a thriving leather trade there and was looking at jackets. The guy showed us a trick which is impractical.
    He took a lighter and ran it across the leather. If it left a burn mark the leather was cheap otherwise it was good. Leather on these jackets was fairly thin.
  6. adventureguy
    adventureguy Well-Known Member
    Veteran
    shopkeepers in dharavi have lighters with them so that if you ask them to do that burn test, they'll do it right then and there
    vivek.krishnan likes this.
  7. nRiTeCh
    Veteran
    Leather stuff is the identity of dharavi. So even if you are a noob you will get original genuine stuff but might get looted thats it!
    If some stuff costs 1k they will quote you 1.8k so you will bargain anyway above 1k and they will be still in much.more profits. If you are aware of the costs then you will directly bargain under 1k and the seller is quick in making out that you surely do know something about there etc.
    vivek.krishnan and adventureguy like this.
  8. OP
    OP
    John4321
    So does any one know or purchased from any shop in Dharavi who sells really good leather and they have used since past couple of years
Share This Page
