Government looks to hike minimum internet speed to 2+Mbps
6pack
ex-Mod
Sep 19, 2005
7,706
1,611
302
Source: Economic Times
Days of low internet speed on mobile and broadband networks could soon be over. The government has kick-started the process of giving a boost to the minimum mandated internet speed from existing 512 kbps to at least 2 mbps and more.
Telecom secretary Aruna Sundararajan said the government was mindful of slow internet speed experienced by internet users in many parts of the country . Internet speeds are nowhere close to the numbers promised by companies in 3G and 4G data packs and advertisements. And, the issue is critical as India prepares for rollout of 5G services as well as a host of other applications focused around internet-of-things (IoT).“We are very slow . While we have done a lot on (providing internet) access, we have not been able to actually deliver the quality of service that is required,“ Sundararajan told TOI here.
The telecom secretary said India required faster speeds in the wake of gradual transformation of the country into a digital economy . These include initiatives such as smart cities, digital India programmes, efforts on digital payments, and 5G.
Asked whether 2 mbps -which is also being pushed for ward by regulator Trai -will be sufficient for digital transformation, she said, “2 mbps is the basic minimum. We should definitely mandate this. If at all, it should be higher than that. It cannot be lower than that.“
The issue of slower internet speed has been a painful experience for a majority of mobile customers, especially when download speeds for videos and other such services is nowhere near the satisfactory level. All this is happening at a time when telecom companies are rolling out faster 4G networks across the country , a move that has gained pace after the launch of services by Reliance Jio in September last year. Older telecom companies, however, have been averse to the idea of having a higher threshold when it comes to internet speed.
“Their main concerns in this regard were limited availability of spectrum per operator in 2G3G bands; low coverage zones such as basements, high-rise buildings, tunnels; and variations due to external factors such as subscriber's device quality and type, number of subscribers browsing the data services, peakoff-peak time, transmission bandwidth, website behaviour, etc,“ Trai said in its `Consultation Paper on Data Speed Under Wi reless Broadband Plans' released in June this year.
However, they are cold to criticism -levelled in many quarters -that investments in boosting mobile network infrastructure have been weak.
A recent global report based on over 63 million internet speed tests across the world ranked India at 119th position in a list of 189 countries where the tests were conducted. The report by Cable.co.uk said to download a 7.5GB HD film, it will take only 18 minutes and 34 seconds in top-ranked Singapore and under 30 minutes in Sweden and Taiwan, but the same would take a little over 8 hours and 16 minutes in India.
6pack
ex-Mod
Sep 19, 2005
7,706
1,611
302
They should make it minimum 10Mbps imo. 2Mbps divided by 4 devices in a house = around 512Kbps per device. Every home has atleast 4+ internet connected devices now. Cant even stream 480p resolution videos on YouTube or other video sites on 2Mbps properly.
Reactions: Julian
vivek.krishnan
Veteran
Dec 18, 2009
7,481
1,678
303
Ghatkopar, Mumbai
plus.google.com
Let them start with something. 2M is good for starters.
On a different note, we should make it easier for the bureaucrats to decide minimum speeds by showing them ease of watching YouPr0n with 2M, 4M and above speeds, and with/without HD versions so they can see the stuff in *ahem* full graphic detail :p
meetdilip
Oct 9, 2011
668
106
81
First, I would ask for clean drinking water for all.
That aside, it will take years from govt framing policy and it gets implemented.
Reactions: nimod
