- Q: What is your budget?
55K - Q: What is your existing hardware configuration (component name - component brand and model)
Logitech Z623 - Q: Which hardware will you be keeping (component name - component brand and model
Logitech Z623
- Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement Nothing as of now
- Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component?Final Configuration
- Q: Where will you buy this hardware? (Online/City/TE Dealer)
- New Delhi
- Q: Would you consider buying a second hand hardware from the TE market
- No
- Q: What is your intended use for this PC/hardware
- Gaming
- Browsing
- Watching HD movies
- Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
No - Q: If you will be playing games then which type of games will you be playing?Skyrim , FIFA , Batman: Arkham City , Saints Row 3 , BF3 , COD , etc
- Q: What is your preferred monitor resolution for gaming and normal usage
1920x1080
- Q: Are you looking to overclock ?
No .
- Q: Which operating system do you intend to use with this configuration?
- Windows 7
- Windows 7
---------- Post added at 11:56 PM ---------- Previous post was at 11:54 PM ----------
Display size atleast 22 inches.
Speakers I already have.
Will also need to buy a UPS.
