Budget 0-20k help me ,whether following selection of components will work.
abhi2407
Recruit
hi,
please help
i am planning to get an assembled desktop.
will the following configuration will work?
cpu: Intel 3.3 GHz FCLGA1155 Core i3 2120 Processor
motherboard: ASUS P8H61-M LX Motherboard
cabinet: iBall i2511 Mid Tower Cabinet(comes with smps)
cabinet fan: Cooler Master BC 80 mm Red LED Fan Cooler
RAM: Corsair DDR3 2 GB (1 x 2 GB) PC RAM (VS2GB1333D3)
HDD: Seagate 250 GB HDD Internal Hard Drive (ST250DM000)
optical drive: Sony DRU-880S Internal Optical Drive (Black)
plz also suggest something better if possible in the same budget
abhi2407
Please fill the information in the right order like all the TE member do and we can help you with the best idea to buy the assembled PC.
Use this template [for queries pertaing to a potential RIG build] please and fill it with the appropriate details.
hi,
please help
You have not mentioned the budget and where you will purchase these components from? Please clarify, over!!
Also I will ask you to avoid the iBall [and in extension all cheap cabinets as far as possible] for your RIG build, the 80mm fans are legacy products, better go for a proper cabinet and outfit it with ~120mm fans.
hi,
please help
Change the Cabinet with this cabinet
NZXT Gamma MID TOWER Black interior chassis
Ram: Buy Corsair Vengeance RAM | Buy Corsair Memory in India
Change the cooler master 80mm fan with silver-stone or cooler master 120mm led fan
