Budget 51-70k Help Needed for 1080P Gaming PC Build
suva71
New Member
3
0
1
Durgapur
  1. What is your budget?
    • 70k
    • Will build everything from scratch.
    • HDD, Speakers & Logitech Gaming Mouse
    • Rest, I'm open to suggestions.
    • Open to suggestions.
    • can upgrade ram in near future
    • Locally from Kolkata
    • Open to online purchase
    • Yes
    • 1080p Gaming of latest "AAA" titles
    • Day to day office works, watching HD movies
    • Nothing as such.
    • GTA V, Far Cry 5, Battlefield Series, other FPS & RPS.
    1. Gaming - 1080P
    2. Desktop -1080P
    • Yes
    • Windows 10 Pro (64 bit)
indy1811
Veteran
Dec 24, 2006
2,157
299
172
Intel Core i5 8400 -12850
Asus Prime 360M - 6250
8GB DDR4 RAM - 5250 (16GB if budget permits)
Zotak Geforce GTX1050ti 4GB - 10900
Corsair 100R Cabinet - 2200
Samsung 860 EVO 256GB SSD - 4850
Corsair CX550 - 4500
LG 24MP59G - 11700
Logitech G100s combo 2000
Add 18% GST to these prices. Got it as a quote from SP Road, Bangalore
suva71
New Member
3
0
1
Durgapur
LG 24MP59G - 11700
Thanks, kindly give an amd based configuration also
Gilarqt
Banned
14
1
3
I would suggest if you can factor it in, 16gb of ram. 8gb used to be the sweetspot, but is now found wanting on new AAA games. If you stick with 8gbs go for 2 x 4gb kit to ensure you have dual channel running. Games like BF1, COD WW2, Wolfenstein use upwards of 8gbs at 1080p.
bssunilreddy
Veteran
Mar 24, 2007
2,091
813
207
41
Nellore
plus.google.com
Any help?
AMD Gaming RIG
Budget -85K
Processor -AMD Ryzen 5 2400G -13k
Motherboard -MSI B450 Gaming Plus -10k
Graphics Card -Zotac GTX 1060 6GB Mini -23k
RAM -Corsair Vengeance LPX 3000Mhz 8GB -6k
SSD -Samsung 860 EVO 500GB M.2 SSD -9k
Power Supply -Antec Earthwatts Gold Pro 550w -6k
Cabinet -Cooler Master Masterbox LITE 5 RGB -6k
Monitor -BenQ GW2280 22 inch LED IPS -8k
KB & Mouse -Cooler Master Masterkeys Lite L Combo -4k
Total -85k
bssunilreddy
Veteran
Mar 24, 2007
2,091
813
207
41
Nellore
plus.google.com
Any help?
Budget -73K (GTX1050Ti)
Motherboard -Asus Prime B450M-K -7k
Graphics Card -Zotac GTX 1050Ti 4GB Mini -13k
SSD -Samsung 860 EVO 250GB SSD -5k
Cabinet -Antec P8 ATX Cabinet -5k
UPS -APC 1.1 KVA -6k
Total -73K
