Budget 31-40k Help Needed to Choose Between Two gaming PC builds
I am planning to buy a gaming rig which costs about 35k
I have made two builds , someone help me choose between the two
PC build No 1-
Processor-Intel Pentium g4560
Motherboard- MSI H110 Pro VH
RAM-Corsair Vengeance 8Gb (1600mz)
Storage- WD blue 1Tb
Power supply-Corsair Vs series Vs450
Cabinet -Cooler master 311
Graphics-Nvidia GTX 1050TI
PC build No- 2
Processor- AMD A8 7600 Kaveri
Motherboard-Asus A68HM-K
Power supply-Cooler master CM 350plus
(New member to the forum, Forgive me if I broke any rules accidently)
I saw the template,but how can I compare between two rigs using that template
It is for just upgrading an existing PC right?
On a 35K upgrade budget, why are you buying the 1050ti, Get an EVGA 1060 from amazon.in global store for around 17K, hard to beat at the price.
EVGA offers international warranty, You only need to pay the price to Amazon & no other customs or charges, the best bang for the buck right now.
this leaves you 20K for the rest of the parts, pretty fine I would say,
H110m mobo- 5K
G4560-5.5K
Now you have 10K left,
Decent budget psu - around 3K
4gb ddr4 stick -2K
Case-1K
1tb hdd-3.8K
There you have it, the fastest pc on a 35K budget in India that you can build.
H110m mobo- 5K
G4560-5.5K
4gb ddr4 stick -2K
Case-1K
1tb hdd-3.8K
Brother , I am gonna assemble the computer at local shop. I had enquired and EVGA parts are not available.
Thank you of suggesting a great build
Can you also help me by saying which among the two builds which I have mentioned is better
any reason for not buying online? you can save a bomb on gpu.
you wont find EVGA in local stores, amazon.in global store is the only way
also a 1060 is basically a gtx 980, you will be able to run every game maxed out at 1080p
Get an RX470 over 1050 ti around 15k,its miles ahead of 1050ti and almost catches up with rx480/1060/980
1050ti is 11K on amazon
You can go for the first one since based on many reviews g4560 seems to have a sweet price spot and definitely a good cpu for gaming. Though it might still struggle in heavy cpu usage scenarios but then again you stiil get good performance for that price.
Also what gtx 1050 ti are you planning to get? It has 2gb and 4gb versions.
Also, you can use this sites to compare prices with your local dealer:
https://www.primeabgb.com/
https://www.mdcomputers.in/
I'm planning to buy the 4 GB version
I checked some local shops ,the price at local shops are less
But im having confusion of which brands 1050ti I should chose
I'm taking the 4gb version.local prices are less compared to online. Im confused bcoz 1050ti comes in different varieties ( diff brands, diff no of brands,diff no of fans)Please help me out
Budget -38.3K
Processor-Intel Pentium G4560 -4500,
Motherboard- MSI H110-Pro-VH -4500,
RAM-Corsair Vengeance 8GB 2400Mhz DDR4 -4500,
Storage- WD Caviar Blue 1TB -3500,
Power supply- Antec VP550P -4000,
Cabinet - Corsair SPEC-01 -3500,
Graphics- Zotac GTX1050Ti OC -13000,
KB/Mouse - Logitech MK200 -800.
TOTAl -38,300.
Monitor - LG 22MP68VQ-P 22" LED IPS -8800.
You can buy from https://www.mdcomputers.in/ or from https://www.primeabgb.com/
Go for the AMD build and try to look for a AMD card as they make it prepared for years to come. Will try to suggest any alternatives if I can after doing a bit research.
